Firestone for replacing tires?
Spend the $. Employee of mine had her Corolla pump all its oil onto street after tire center oil change left filler off. Took months to get cap replaced, but car ran ok.
Willing to risk 32 valves and a couple turbos on saving $150? BYO Oil if you wish, but it's like the gas station sushi commercial.
At Firestone they use this coats tire machine http://www.sjdiscounttools.com/coa70...tm_content=pla looks pretty good to me and fairly foolproof I'd think.
I think I'll wait on the oil change till the car is back up north in May, right now the oil has 6300 miles on it, I think I should be around 10K miles by the time the car is up north as long as I don't drive the car too much. I have a friend who owns a Mercedes shop up north and he does the oil changes for 40 bucks for me if I pick up the oil at walmart, I use mobil 1 European formula. Oil has come such a long ways in recent years it allows for these extended intervals. I checked the oil today and it's right on full and does not look too dirty. I just make sure to put all my receipts in the book incase of warranty questions should something go wrong. I'm going to stick to the 10K oil change intervals, I think the new synthetic oils of today can handle it. I know quite a bit about this subject as I use to own Quick Lube businesses before I retired.
I'm really happy with the Bridgestone Pole Positions I bought on Tire Rack, all four tires including shipping and install only set me back around 1000 bucks, not bad. The car seems to handle fine and on the way home I got on a back road and did a couple wide open throttle starts, I think they hook up even better in the rear than the Conti's did. There was something wrong with the Conti's the car was wondering a lot, something with the belts I think. There was a plug in one of the rear tires near the sidewall that the previous owner of my car must have had done, no wonder the tire was leaking around 4 lbs of pressure a week. Good thing I replaced the tires.
Regards,
Joe
