Wheel fitment
http://www.ebay.ca/itm/Gunmetal-E63-...item56608dea2c
Or there is also one with +45 offset
Rears I would go with the +45.
35 offset in rear with poke out 17 mm more (may rub fender) and give you 17 mm more inner clearance.
With a 45 rear, you will stick out 7 mm more (like running a 7 mm spacer) and get 7 mm more inner clearance. Both of which should be fine.
X
http://www.powerwheelspro.com/shop/p...248p917ktfnvq0
They have both offsets. Call them and see about a set with tires and tpms as a package.
Good luck
X
