Minimum thickness Front Discs
Hey, can anyone tell me where to find the specs on minimum thickness for front ceramic discs on a W212 (2012)? Want to check them before I go in for a b0 service as I just know that the dealership will say they need to be replaced.
Thanks!
Thanks!
The spec for minimum rotor thickness will be stamped onto your rotor hats. Either wheel side or hub side.
I believe the dark circle on the outer edge of the rotor face also indicated wear status. But I could not tell you how, exactly.
2008 Saab 93 TurboX SC (BSR stage 1)/2014 E63 S Wagon (Rebellion Tuned/Renntech Sport Mufflers)
I zoomed in on a google picture of the CCB and it says 38,5 mm... not sure if they are all the same on every vehicule...
Factory specs based on the entry 'BE42.10-P-1001-08P'
The service MAX is what the dealer uses when the tell you that you need brakes.
MODELS: 212.070/277
FRONT:
New - 36mm
Wear Limit (consumer MAX) - 33mm
Wear Limit (service MAX) - 33.5mm
REAR:
New - 26mm
Wear Limit (consumer MAX) - 24mm
Wear Limit (service MAX) - 24.5mm
FRONT:
New - 36mm
REAR:
New - 26mm
