2011 E63 Needs Battery?
Old Apr 26, 2015 | 04:47 PM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
This car is not yet 4 years old with 31000 miles.
OBD Has shown stored trouble codes for "power supply, low voltage" across all systems. It suggests the battery has run dead at some point shortly before I bought it.
4 to 5 years is fairly common for a battery so I suppose it could be due. Might have gone dead sitting on dealer lot not being driven.
Another sign that something is wrong is my plug in radar detector. Every morning when I start the car the detector (9500i) chimes "low voltage, please unplug" then shuts off. It never did this in my other cars. After the engine runs for about 15 seconds everything is fine.
So I have an appointment with the dealer on Wed. Likely going to need a new battery. THE QUESTION IS:
Should I pay them to replace it at some overpriced price, or should I put it in a aftermarket battery myself?
Any idea what they will try to charge me?
Old Apr 26, 2015 | 04:57 PM
robl45's Avatar
2011 AMG E63
Isn't battery covered under bumper to bumper?
Old Apr 26, 2015 | 05:07 PM
Vrodman's Avatar
I dont think so. But I hope I am wrong. I would think it would be considered like brakes or tires.
Maybe under the original 4 year factory warranty it is. Kinda doubt it though.
Old Apr 26, 2015 | 05:32 PM
robl45's Avatar
2011 AMG E63
I didn't think so either, but it was covered under warranty on my corvette. Otherwise, wait for sale at advance auto parts. Batteries are cheap and warrantied well.
Old Apr 26, 2015 | 05:37 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
Is the outlet that you are plugging the radar detector into powered when the car is off? If so, the detector may be draining the battery.
Old Apr 26, 2015 | 06:54 PM
Vrodman's Avatar
Nope.
Plugged into cig lighter at front base of console. Radar detector turns on automatically when engine is started.
BTW, anybody know if I will need any security code to enter if I replace the battery?
My 2000 E55 had a 4 digit code I had to enter as security against radio/head unit theft.
Old Apr 26, 2015 | 08:48 PM
Keep 12 volt power to car through jump terminals while changing the battery then nothing needs resetting.
Old Apr 26, 2015 | 08:52 PM
Vrodman's Avatar
Yeah, I was thinking that. Basically connect my trickle charger to terminals while replacing battery.
But I am still curious if anything on this model needs to be re-activated if I dont supply the outside 12v
Old Apr 26, 2015 | 09:18 PM
ERC4's Avatar
'12 E63
Yes, it's covered. The battery in my 2012 died just shy of 3 years old at 26,000 miles. I didn't even go to the dealer. I called MB roadside assistance and they replaced it in my garage for free.
Old Apr 26, 2015 | 10:14 PM
Vrodman's Avatar
Sweet!
That's great news. I just priced one at local parts place, O'Reilleys, and it $175 out the door with core.
Looks like I wont need to worry about that though!
Thanks.
Old Apr 26, 2015 | 10:20 PM
Originally Posted by Vrodman
Sweet!
Thanks.
If you do purchase a battery make sure it is an AGM battery that meets Mercedes specifications.
Old Apr 26, 2015 | 10:40 PM
Vrodman's Avatar
It was.
Thanks though for the heads up.
Old Apr 27, 2015 | 10:43 AM
tpick23's Avatar
E63
I had to replace my battery a few months ago too. Drove to work, came out later and car totally dead. Called MB roadside and they came out to diagnose, ended up replacing the battery on the spot in my work parking lot. covered by warranty
He said the codes would store long enough to change the battery so no special attention needed for this. Sure enough, no need to reset anything.
Old May 1, 2015 | 05:24 PM
Vrodman's Avatar
UPDATE
So my car is still at the shop and they are keeping it over the weekend to finish up things on Monday.
They gave me a status call today on my various requests.
Regarding the battery, it looks like the battery is actually OK. The following I thought might be of interest to someone on the site:
There is a software bug that causes a low output voltage when the engine is first started in idle. I was told they "flashed the software fix" and now everything should be fine.
The only reason I noticed something was wrong is because right after starting the engine, my radar detector would sound an alarm and say "low voltage, please unplug" and then it would shut itself off. I would simply wait 5 seconds, and then turn it back on and everything worked normally. This radar detector has never done such a thing in any other car I placed it in.
