My first track day video
Old May 29, 2015 | 06:25 AM
ucla95's Avatar
E63S, RRS SVR
Originally Posted by unagi1
Won't turning off distronic plus disable the radar used for pre-safe?
Almost positive no.
Old May 29, 2015 | 12:34 PM
MPR's Avatar
MPR
E63S Estate
Glad you had fun. Maybe get most of your braking out of the way so you can transfer more weight to the rear and minimize some of that understeer?
Originally Posted by cnolke
Similar experience here. Quickly overheated the front tires. In a 20-minute run group that meant 5 minutes balanced handling, 15 minutes understeer.
Two 20-minute run groups completely consumed my front Contis and the remainder of the stock brake pads.
Racingbrake.com makes a very agressive racing pad if you'd like, but it was back to the Z06 for me.
I also had PreSafe go off a couple times before I figured I had to stay away from other cars in the brake zones. Luckily I managed that pretty easily without killing the fun. Its a very fast car, but not a good track car at all.
The crazy people that took the E to the track will fully understand. For me was braking and handling was good till about 10 minutes (6 laps). That is only if you try to balance the tire/brake overheating issue with speed. I am still trying to get a fast lap in. The last two minutes (7-8 laps) I can sense the front tires is getting overheated and definitely more understeer came out hence I need to go back to the pits. agree its a fast car but not a track car unless you have deep pockets for consumables.
Originally Posted by RossN
Wonder if anyone makes some Brake Ducts that will help with heat dissipation?
Would love to see the wagon with some proper brake tuning, dialed in suspension tuning, and proper lightweight wheels and RACE SLICKS! That would be fun...!
Originally Posted by MJ50
nice video...
do ecu tune and overtake the porsche next time...
I don't think brake ducts will help with this E wagon and this particular track. Might be a bit better if the track had huge straight away and smooth transition through each corners without a lot of braking. In the end I believe it will still become the same result but you may get more time and sessions in.
As we speak, I'm already working on the brakes (may work with carbotech or RB), suspension (lower it and more camber), and upgraded tires. I got 5 sets of hoosiers/V710 sitting in the garage for that one sunny day. Still debating if I should go AMS or Renntech. The bone stock stuff is to set up a baseline for my lap time and data acquisition. I believe I can cut minimum 2.5 seconds down and this will allow me to pass these car blockers easily.
Originally Posted by HPMan
Bravo to the OP on taking an E to Mission! For others, it is a very short, technical track that is murder on brakes. I've been wanting to take my E out but can bear the thought of burning up a set of brakes in a session or two (I've done that before on a previous car and will only now take a proper track car out).
Originally Posted by jordanfox
good to see an Vancouver owner here.
I'm surprised to see Vancouverites here. Should gather a track day with E63 and C63 all together for a day. That will be a hilarious scene. I do see C63 out there but even that it is a rare event. You gotta bring the E out at least once just to feel what it is like. You don't want the oem dust pads anyways. I wonder what is your track cars.
Old May 30, 2015 | 03:06 PM
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
RB has the most complete brake upgrade for MB C63 & E63, well more than just the brake pad.
As an example we are now offering CCM brakes for C63/E63 as track options
Carbon Ceramic Brake for C63
Brake Series brake upgrade for C63/S/507 is another affordable package to better equip C63 for track task:
Black Series brakes on C63
In addition to our light weight two piece rotors and brake kits, we also offer highly regarded caliper rebuild/upgrade components such as high temperature dust boots, stainless steel pistons, oil seals etc. which are favored in communities such as BMW, EVO, Camaro, Corvette, Porsche, GT-R where track racers tend to burn out the OE dust boots, and crack their pistons.
http://www.racingbrake.com/Caliper-R...ice-s/6997.htm
Old May 31, 2015 | 11:58 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
THERE IS ONLY FRONT AND REAR TOE ADJUSTMENT OEM!
AT K-MAC WE SAW THE NEED AND MANUFACTURE PRECISELY ADJUSTABLE (SINGLE WRENCH, ON CAR) FRONT CAMBER AND CASTER AND REAR CAMBER (WITH EXTRA TOE) KITS.
Track days adjusting front for extra negative Camber, track width and less understeer. Along with extra positive Caster for reduced dive, lift, quicker turn in.
While rear adjusting, fine tuning also for maximum traction, tire wear or to reduce oversteer, increase track width.
Alternative (for front only) is the inaccurate "one only position" offset fluted bolts. But these only offer .3 of one degree (1/8" / 3mm) and to change setting means labour intensive dis-assembly each time.
The K-MAC system offers 3 to 4 times the adjustment range with precise (ongoing) adjustment capability - adjustment being carried out accurately (under load direct on alignment rack).
It means also no more repeat trips to dealers or alignment shops trying to return vehicle to factory specs to resolve steering pull or premature, costly inner edge tire wear. The result of curb 'knock' damage worn bushings. load carrying, altering suspension height or fitting wide profile tires/wheels.
For the rear - there is available "Camber Arms" -
But these upper arms to reduce inner edge rear tire wear need to move top of tire outwards reducing essential clearance "top of tire to outer fender".
The K-MAC patented design bushings resolve this problem by adjusting lower, not upper arms (front and rear). They also replace the main (highest wearing) suspension bushes at the same time and have twice the load bearing area. With the front K-MAC bushings being 2axis/self aligning without the OEM oil filled/air voided bushes.
Result is improved brake/traction and steering response. Note - most aftermarket bushings (even though oil/air voids are deleted) wheel hop, loss of traction can increase. As today's multi link suspension arms are therefore restricted and can bind, lock up as they are prevented from travelling through their required arcs.
All kits come with instructions and bush extraction/insertion tubes
(MB World Member Heiss Rod has kindly provided step by step picture sequence re front bush installation.
Watch: https://mbworld.org/forums/w211-amg/...-airmatic.html
See 2015 Catalog: http://K-mac.com/mercedes/
$480US Front kit
$480US Rear kit
Special promotion price delivery for MB World members USA/Canada $30 one kit or $40 for front and rear (average delivery time is 3 to 4 days). Payment can be made using Vis, Mastercard or PayPal.
