Rotor Rust
Old Aug 31, 2015 | 11:14 PM
Davidkuo0330's Avatar
2016 AMG S65, AMG GL63, 2012 AMG E63 With AMS Alpha 9 Package, Renntech 200 Catted Downpipes.
Rotor Rust
Hey Guys. What is the best way to get rid of rust from your rotors? Is there something you can buy and spray it on and then wipe off? How can you prevent rust? Many thanks.
Old Sep 1, 2015 | 03:46 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Drive the car around the block and the rust will be gone. It's normal and nothing to worry about.
Old Sep 1, 2015 | 07:40 AM
silvers2k's Avatar
2012 E63 AMG, 2013 E350 4matic (SOLD), 2006 C55 AMG (SOLD)
I suspect you are probably referring to the middle part of the rotor (hub) and not the actual rotor itself. I noticed the rust on the hub myself and purchased Griots Garage rust removal gel (spray on and rinse off with water). The gel didn't do squat for me. I'm going to most likely paint the hub with high temperature paint when I paint my calipers.
Old Sep 1, 2015 | 11:37 AM
Sorry, but I was referring to the rotors itself.
Old Sep 1, 2015 | 12:56 PM
HPMan's Avatar
2014 E63 S
As noted, simply drive and the pads immediately scrub the rust off the rotor. The rotors are iron, so they will rust and there is no way or need to prevent surface rust from forming.
Old Sep 1, 2015 | 03:11 PM
Thanks guys.
Old Sep 1, 2015 | 04:46 PM
NedNederlander's Avatar
'19 e63s, '98 Z3, '09 CLK550
I will just agree that the Griot's Rust Removal is a waste of money. I, too, have rust on the hub and have been living with it.
Old Sep 2, 2015 | 12:50 PM
M and AMG's Avatar
M3 & E63 & SL55
You can always paint the hub black if it bothers you that much.
Old Sep 2, 2015 | 02:41 PM
2012 merc amg's Avatar
2018 S560
I managed to get a wire brush and do around the inside of the Rotor and then paint it with high temp gray paint on all the wheels, the color is similar to the Palladium gray and glossy and it looks great now, did that when I first got my car 2.5 years ago as there was rust there, it seems to be holding up great. I'm surprised they don't paint this better at the factory.
Old Sep 4, 2015 | 05:21 PM
BrabusNYC's Avatar
2014 E63S
+1
