Coding headlights to euro spec?
merc doesnt like people messing in their software...I too came from audi world and vagcom / lemi-tweeks were great, but sadly MB is definitely less tuner/user-friendly
I do have the software for the W212 on my DAS, just never tried it. I will over the weekend and report what I find
tuning would be more like,on the e55 w211, try to get past MAP readings of 18+ psi and see if the ecu doesnt cut fuel and then tune in a work around
please tell us m157 guys how to turn off the low rpm torque limiting that MB has hidden in the code somewhere.... GAD in germany still hasnt figured it out on their 1100+hp e63 so im guessing its not in star
one example of how much easier Audi/VW is to tune, You can actually read and write ME7 ECUs with a cheap vagcom cable.... there is no such similar cheap tool for mercedes guys
that's main thing keeping the m157 from really cracking under 1.7 sec 0-60ft times
I did mean user friendly enough. Yes minor changes in software configuration. I even set my E55 AC to have recirculation at any speed under 30km/hr and fresh air above that. I changed from air suspension to steel and converted the car to coilovers with no error messages, etc etc
In the case that the OP was asking about, if the STAR software for the W212 chassis is up to date, a lot of this can be done
