Latest map version and keyless entry issues
Old Dec 4, 2015 | 01:20 PM
Astolfo's Avatar
I have a 2015 e63s and was wandering what is the latest map version and if anyone is having issues with the keyless entry, most of the time I can't unlock or lock my car unless I use the key...
TIA
Astolfo
Old Dec 6, 2015 | 11:06 AM
grimesch's Avatar
2015 AMG E63S 212
I hope you are not still "wandering" with your map version. We have the '15 wagon also, and have found that some of the new roads in our part of Florida are not in the database. I am going to pursue with our dealer when we return to Vermont.
Regarding the keyless go anomaly, we had two trips to dealer to sort out. It was a software upgrade that solved it and I think there is a service bulletin on that problem.
Old Dec 6, 2015 | 01:17 PM
kponti's Avatar
E63
Change your remote battery. I know it's probably new, but mine worked a lot better after changing battery after only a few months
Old Dec 6, 2015 | 02:13 PM
marcolarco52's Avatar
homeless
Your keyless entry is a software issue had it happen to my car at least a dozen time before I got fed up and took it to the dealer (each time it happened I had to remove the battery and put it back in for it to re recognize the fob). There is a software update regarding the issue. Took them a whole of 15 minutes to update it.
