o2 sensor problem/vibrating low rpm
Old Dec 10, 2015 | 12:37 PM
Adams.e55's Avatar
E55 w211
hi i have problem with my e55 2004 first one i have a light check engine on with error (p2082-008 g3/3 left sensor ,before twc9kat) short circuit in signal line (p0151) i put new bosh sensor delated error after few miles error back.and second is a vibrating on low rpm with load around 1200-2200rpm when is engine hot.is that 2 thinks can be connected ?or maybe conventer has enough already?any idea where to start?trany mount changed
Old Dec 13, 2015 | 10:10 AM
kponti's Avatar
E63
That is a w211 vehicle, probably get a lot more help posted in that forum.
That being said, low rpm vibration is all too common on the E55s. Nothing wrong with the car with that problem usually.
As for the code, I'm being too lazy to look them up so maybe someone else will help
