pp performance
1-i just got my car tune by pp performance
after the tune 4-5 days the car is lossing power and coming back to stock power
i checked the car no problem did this happen to any one before
2- one problem 2 year ago very one or two week the engine viberts like hell and when i turn the engine off and back on it dispir i don't know what is it
and it is sill there
EDIT: Its clear my "humor" did not come through on this so let me add. Sure I did not know who PP performance were, but I did assume they were real but from somewhere outside of the US.
http://www.pp-performance.de
heres their e63 4matic going 10.13
US and Europe calculate it in different ways which makes US fuel look like it has a lower rating but in reality they've got the same rating. US shows the average of the Research Octane Number (RON) and Motor Octane Number (MON) rating, which is the Anti-Knock Index (AKI) also known as (R+M)/2, while Europe just shows the RON rating which gives a higher number than the MON rating.
super in usa is 93 (R+M)/2.... in germany its 98 RON.... same octane just different measurement method... kinda like measuring gal here vs liters there... 1 gal does not equal 1 Liter, just like 1 (R+M)/2 (usa measurement of octane) does not equal 1 RON (european measurement of octane)
And yes modern ECUs will compensate but not by adding a bunch of power.....they compensate for lower octane by pulling timing thus reducing your power
Now if you put a higher octane in there such as race fuel you may pick up some power that you otherwise werent getting because your knock sensors were telling your car to pull timing on your regular file , but then when you put in a higher octane you got slightly less detonation / knock and so your ECU pulled less timing( does she picked up a little power that you were previously losing) but it's certainly not adding timing beyond what your car was already tuned for on regular gas
I was referring to the E63 tuners you yourself referenced
-You might want to check with PPP as well to see if they have some more info for you since you just got the tune
What year is your car? How many miles on it? Are you on factory plugs?
You're also the guy that thought PP performance was somebody's idea of Punkin you
Carry on lol
Carry on lol
Renntech's response was, "we gave you our best tune, check with dealer if you aren't getting the power you should have"
AMS did not ask for a octane when I was considering going with them (changed my mind cos my car is CPO and my dealer did the Renntech for me). Renntech told me they have the same tune regardless of 91 vs 93 octane (I have 93 octane here, the difference is simply 1 or 2 degrees of timing anyway on the top end if I had to guess)
Oh I was not asking for why I was not making power, I was showing the power delta in my case with Renntech. I did have some misfire though after the tune and it was a concern to me.
