Carbon Ceramic rotors dead at 18K miles
where you not changing your pads after heavy track use?
18K seems way short of what CC rotors should last
I would have another MB dealer take a look at it.
Good luck.
As David said, I would get another MB dealer to look at it, and then progress to MBUSA.
They don't wear down like a normal rotor, which is why the dealer doesn't measure thickness. They will stay the same thickness, but high temperature from track use will cause them slowly break down internally and essentially evaporate causing the density to reduce while the dimensions remain the same. The more exposure to very high temps, the faster they will deteriorate. However, I didn't think it would be as fast as you're experiencing. The fact that the E63 is such a fat pig means that we get higher rotor temps lap after lap than a 911 or Cayman with CCBs.
Please keep us posted.
Also have you guys been paying attention to all the problems with these new cars. I believe that overall craftsmanship, quality of materials used and quality control has suffered greatly over the past several years.
Greed and ego runs these company's. It's what has brought VW to their knees.
Hope it works out for you.
Bill
Needing new CCB rotors after a couple of track use and 14,000 miles just doesn't add up. CCB are
meant to be abused, but as a daily driver. I would hardly consider it abused to the point it would need replacement after 14,000 miles. I spoke to my service director and he said if he got that car, he would replace the rotors under warranty, no questions ask.
Has quality declined. Of course it has. Everyone wants something great, but want to pay less for it. As a manufacturer, what do you do. Lower your quality standards to meet the price point, period.
Bill
18k miles is a lot of miles for a 15my IMO. We don't know how this car has been driven on or off the track. If the car was driven hard for 18k miles and tracked hard about ten times I can clearly see the brakes having an issues.
The simple fact is that there is a major wear issue with the breaks. So one of two things has happened: the car has been driven very hard over its life or the materials used to make the brakes is subpar.
Bill
not to mention these street cars should get longer life out of CCB since they are not tracked daily like the race cars you are comparing them to
plus the porsche guys (CCB rotors from same company that makes them for AMG) are getting wayyyyyy more miles out of their CCB and they are way more hardcore track guys than the typical AMG guy.... CCB are supposed to last ~100K miles with occasional track use... but i know guys that track their porsche's every weekend and have over 50K on their CCB's with no problem
Beating a dead horse here.
At the end of the day if you drive a four door sedan weighing about 4500 pounds hard for 18k miles I don't care who makes the brakes your going to have wear problems.
Anyone who takes a 15my e63 to the track about ten times clearly enjoys hard driving. I doubt this joy stops after leaving the track.
I've driven many brand new cars and trucks every car brand hard on the street for my job and our brakes lasted only a few thousand miles before we needed new pads.
so if the op's CCB's really are done at 18K then he would of been tracking his car so hard, that if he had standard disc they would of only last 300 miles...... hard to believe the OP was racing that hard
Do you know how this car has been driven? If the answer is no than your in no position to fully understand what caused this.
The simple fact is, if the op is being truthful, this is what happened end of story.
lol or could be, as OP is worried about, is getting bent over by the dealer when in reality no change is needed and the dealer wants money
and we do know how the op drove them... 10 track days he said.... other than that, you arent getting much extra on the street... again its not the force of the braking on the CCB's that affect life like steel ones.... so the only "extra use" the OP's CCB's saw were however many applications of the brake pedal during those 10 track days....I am sure they did not add up to the amount of times he would of touched the brake pedal in 82K miles of driving (100K expected miles - 18K miles he got)..... now, if in those 10 track days he touched his applied his brakes as many times as he would in 82k miles of city street traffic, then it would be logical that he is only getting 18K out of his CCB's.... BUT i highly doubt he got that many brake attempts on regular Joe Shmo track days... maybe his 10 track days were each 72 hr endo baja races?
given the real data that is know about CCB wear, i would say the dealer wanting extra money is the more likely scenario
and we do know how the op drove them... 10 track days he said.... other than that, you arent getting much extra on the street... again its not the force of the braking on the CCB's that affect life like steel ones.... so the only "extra use" the OP's CCB's saw where however many applications of the brake pedal during those 10 track days....I am sure they did not add up to the amount of times he would of touched the brake pedal in 82K miles of driving (100K expected miles - 18K miles he got)..... now, if in those 10 track days he touched his applied his brakes as many times as he would in city street traffic, then it would be logical that he is only getting 18K out of his CCB's.... BUT i highly doubt he got that many brake attempts on regular Joe Shmo track days... maybe his 10 track days were each 72 hr endo baja races?
I love mine and they show no sign of wear, but I do only have 3k miles on the car and I have never tracked the car.
Next month my 2017 911 turbo s cab arrives and will have the ccb. Now I may hit the track with this beast.
You can resurface CCB 2-3 times depending on how much they wear down over their life. Now that RacingBrake has this procedure it TOTALLY changes the economics of carbon ceramics. I will only run CCB from now on, even for the track.
Hope that helps
Good luck.
