M156 AMG compression problems!
My car is weistec st3, I have repaired the engine pistons on weistec, after that i have problems, Almost everything about the car changed, but Did not help,The engine still works unevenly has missfires,Compression is checked and found to be in the driver's side cylinders (5,6,7,8) has 13.5 and 1,2,3,4 cylinders 12.5
Thanks in advance for your thoughts
The head gasket issue could be the result of a failing head bolt or 2. Your compression numbers clearly are for a normally aspirated motor which means M156. 2010 or older by any chance?
Good luck. Let us know if you figure it out
Cant think of another way to explain compression difference the way you describe other than maybe a valve difference between left and right heads.
Any case, it sounds like you have made large changes to your motor so without knowing all the details its hard to speculate.
Good luck
