Still dropping pressure in one tire slowly
Received 2,036 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Had this oem tire replaced under my wheel tire protection plan just a week ago and it was filled to 41 all around. Now only the right rear... The replaced tire (had a nail in it) is down to 38 with normal driving and others are at 41
They said (Benz) rim was ok
Thoughts?
Thoughts?
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
maybe the other tires 3 had nitrogen in them and when the dealer replaced and filled the new tire w/ regular compressed air? compressed air will seep slowly out of tire whereas nitrogen wont
Good advice ... Will watch this one week and then take it in again
Thoughts?
Thoughts?
Also, My wife's 2013 GLK has the same problem on the left front. We just put 4 new tires on her car 3 months ago.
Same tire place (Americas Tire) did both installs. Hmmmmmmm????
2016 AMG S65, AMG GL63, 2012 AMG E63 With AMS Alpha 9 Package, Renntech 200 Catted Downpipes.
Hey Peter. Get a bottle sprayer and spray some water on the tire in question. If there is a leak, you should see bubbles. Make sure you rotate that tire so the water is sprayed on evenly.
Good luck.
Good luck.
This happened on my vette and also on my amg. With the vette people said the way the right rear tire spins can cause the sensor to loosen. Try to tighten it up a bit. With the amg. Both rears had nails but only the right rear was losing pressure. So if your sure you haven't picked up another nail. I would tighten the sensor a bit.
I am dealing with the same thing on my 2011, funny enough it is also the right rear tire. I just put on 2 new PSS on the rear about a month ago. Did not have the problem prior to that. I doubt the nitrogen theory in my case since both rears were done at the same time.
This is such an annoying problem
Unfortunately, the TPMS is secured from inside of the wheels so tires need to come off if the leak is coming from the TPMS. Be sure to spray some water on the valve stem and see any bubbles are coming from there.
Good luck Peter. It might be a good time to put the wheels insurance to good use.
on the outside, you will see on the step there are some steps around the valve step, you can put a wrench and tighten a little bit. lightly of course, you don't want to break anything. When I did it on my right rear tire, the thing was relatively loose and tightened a bit with the wrench.
Just had them replace that tire last week and mount new tire cost $478 to them.
Will try the water trick and small attempt at tightening
Thanks guys
Mixed some Palmolive with water to a nice viscosity and applied to valve stem circumferentially
No obvious bubbles; didn't get a chance to apply to entire tire yet
Right rear (problem tire):
Pressure yesterday was 42.5
Today was 41.5
The left rear also dropped from 42.5 to 41.0
I presume some of this is just cooling of atmospheric air; regarding tightening that bolt/valve stem I don't have a socket deep enough to clear the stem to get to the hex bolt... Couldn't tighten it therefore
Will check all around after the drive to work and back
Today was 41.5
I used two separate digital gauges which are similar in readings within 0.5psi with the Benz tpms
Also I have gone 24 hours with lots of driving and that rear tire is holding at 41 psi
Thanks again guys
If I find a screw in the wife's GLK tire, she is not going to be driving my car much anymore! I suspect she drove both vehicles somewhere near a construction area.
I should have known better than to let her drive the beast. At least no wheel curb rash yet. She scraped the hell out of one of her wheels the 2nd day she had the car. Ugh.
2015 AMG E63S 212
I have a similar situation with left rear tire/wheel. Had to replace the wheel in December and put on Hakkapalitas for winter, and now that tire is typically 2-3 psi lower. Yesterday I had new Pirellis (summer) put on rear and after the drive home the same thing is happening. It may well be the TPMS on that new wheel. It doesn't seem to get worse, just that 2-3 psi.
After another week of driving its down another 1 psi
Worth taking it in at this point ?? Just so annoying
AMG GT S & E63 S AMG
1 psi per week is probably within the normal range. Plus, the past few days has been colder so that would affect it as well. It is pretty common for bike tires to lose 10 psi per week and for the front and back tires to lose pressure at slightly different rates. I would wait and see what happens. If it starts losing 3-5 psi per week, then something is wrong.
Why do the fronts stay so damn stable?
Have you checked to see if the needle valve inside the valve stem is tight? Maybe during the tire change, the needle valve got slightly damaged? This valve has to come out before the dismount and only put back on after the bead of the new tire has been popped. Maybe you can have a local tire shop replace that valve and refill the tire and see if anything changed.
