2012 bi turbo only getting 8-9 PSI of boost
Hi all,
I have scan tool hooked up to the OBD2 port that is feeding a app on my iPhone called "DashCommand" that allows you to record all the sensors.
I have it displaying a few things, and I was under the impression these cars stock (non p30) make ~14 psi of boost for their rated 517HP?
I am only able to get high 8, almost 9PSI of boost floored on the freeway in 3, 4, and 5th gear.
Is this normal, or low?
Found this text
From here, http://www.roadtesttv.com/drag-test-...e-road-test-tv
the $7300.00 Performance Package comes from raising the boost through software on the E63′s turbos from 14.5 to 18.8 psi
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
from what i understand on that app is you have to input a few variables when you setup your vehicle such as volumetric efficiency and displacement and the app then interpolates your boost based on map/maf readings so if you have any of your inputs wrong, the calculation is going to be off...
so its not a real boost reading, its an interpolated value
Yeah those apps read crazy numbers at times. It read over 30psi of boost for me most of the time on the dyno
Interesting,
Now that you mentioned that, I went into the app again, it does say it is 'calculated boost pressure' I will see if I can get actual data out of the MAP/MAF sensor.
Thanks everyone!
Just remember that with map readings you have to subtract base atmospheric pressure. Ie 1 bar
