are stock plugs OK with a tune and dp?
I'm going to do a tune and downpipe, should I get colder plugs like weistec plugs or are the stock ones fine?
It doesn't mean you may experience misfires. Some people get them, some dont.
16' E63s Diamond White
Originally Posted by vikingdiesel
Are weistec plugs the most commonly used then?
PLATINUM SPONSOR
I would ask your tuner as well, since some tunes have less hp to run on stock plugs and some offer more with colder plugs. I run the tune with max power and run colder plugs.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
