Disappointed with my track result 11.8 @120
#51
Very unlikely it's anything to do with the hardware since my car ran strong with no issues in the past. I made several dealer visits to ensure my car was running strong before getting the tune. I even asked the dealer to perform oil consumption test just to be extra safe. Then again, anything is possible just highly unlikely.
#53
I'd guess your car is pulling timing for some reason. Could be simple false knock issue or something deeper. Tough to hunt it down without a log.
Good luck.
Good luck.
#61
I think I remeber reading your thread, your numbers are from a Mustang Dyno which reads lower than a Dynojet. Nevertheless, my peak hp is less than your 585whp @579whp.
#64
#65
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
^ yeah, im confused now lol... if at 579 whp then should of ran better than 120mph unless he let off the gas pedal 3/4 way down the track
#66
It's my understanding mustang dyno reads lower than the dynojet. The tuner advertised 634whp on a dynojet with tune only. I suspect the catless downpipes should yield another 10-15whp.
#67
Just to back up my theory again, another forum member posted his quarter mile time. His 60ft time was not much better than mine yet his trap speed is 4mph higher. In fact, I'm quicker by 1mph by the 1/8th mark and I assure you I didn't let off the gas early.
#69
Anyone want to drag race my car (using "soft launch") and if you can get my car to trap @126 I'll give you $500.
#70
do you have stock cooling? I noticed yours is a 2012 and the stock cooling on early models can suffer from heat soak, but i still doubt its whats causing your low trap as you still should be able to get off one good run
#72
Still not a bad number for a tuned M157, pretty regular actually. And definitely not whats causing your 120mph trap speed. Unless you stowed 4-5 200lb dead bodies in your trunk, you should be in the 125-127mph trap speeds at that rwhp
#74
Stock cooling but to your point, I doubt this is the cause of my low trap speed.
#75
