Help Request - 2010 E63 Comand Knob Removal
Does anyone have a write-up or link to a video showing how to remove the Comand Selector Module on a MY2010 E63? I have seen lots of information for the W204 and the non-AMG models but cannot find anything specific to my car.
Thanks in advance.
Thanks in advance.
I have a 2011 and mine was replaced by warranty, just barely. I actually had the car at the dealer getting the pano roof popping (infamous) fixed when mine quit. I picked up the car with one thing fixed and then on drive home realized that the knob was toast. on mine, everything worked except the rotary action. Took it back a week later and they did it.
FYI, I believe the failure issue with this module is excessive heat. Ever notice on hot summer day how hot it gets? almost can't touch it. Well, before I tinted all windows to dramatically lower interior heat in the summer. Hoping that this will keep my module from ever needing a replacement again. We will see.
Please do update us if you find a how-to or if you write one yourself!
Good luck
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
not exactly a 2010 w212 e63, but access is similar and i think it could be reverse engineered with help of this one as location of scroll knob on 2010 e63 is same i think
and here is a pic of the how to get to the screws that hold the scroll ball in ... just remove center console side pieces to access the internals
![](http://i700.photobucket.com/albums/ww2/myfunstore_345/E63%201_zpsd8mzsl7c.jpg)
chris.bachman (09-09-2016)
Has it gotten hot since the module was replaced? Maybe the module itself was already faulty because I don't recall mine getting hot at all.
But it is an interesting point you make.
whew, good thing mine was replaced at 98k right before i got the car. Best of luck to you with it, i agree that the video above should be a good starting point. Post pictures when you do it, will help in case i need another one
Hello everybody,
I am producing a repair kit for your Mercedes Benz Comand Knob. You will get a new aluminum shaft. A nice pry tool kit to protect your interior is also included . You can purchase it via Amazon: Mercedes Benz Comand Knob Repair
You can also contact me via eMail: info@lightoff-airbagmodul.de
Best regards from Germany
