Potential owner looking for common problems
Old Nov 4, 2016 | 12:45 PM
wdbarr's Avatar
2011 E63 AMG
Hello MBWorld!
I'm currently looking at a 2011, and have been doing research to find common issues with the vehicles before I commit to anything.
Currently I am aware of the head bolt issue that plagued most of the M156's, including some of the MY2011s. Valvestud has checked the VIN of this particular W212 and it is post-60658. I'm going to have the dealer take a photo of the engine serial number just in case.
Did the upgraded lifters make it into the post-60658 engines as well? As I understand it, MB now only sells the revised lifters with oil drain designs similar to the SLS M159 engine. However, there's a lot of confusion on whether they were also changed over on production vehicles when AMG changed the head bolts over on 60658.
Also, cam adjusters. I see that the W204 C63s are having the "cam adjuster rattle on hot startup" issue much more frequently than other M156 cars, and as I understand it they also had a different design for their cam adjusters. How prevalent is this failure on W212s?
Finally, is there anything else I should be looking at? Any common problems at all would be incredibly beneficial to me.
Thanks for your time!
Old Nov 4, 2016 | 02:37 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
Glove box light wiring will fail after a while due to wiring wear from opening and closing.
Old Nov 4, 2016 | 05:49 PM
2012 CCB E63's Avatar
2012 E63
You should be looking for 2012+ cars
TT > NA
Old Nov 7, 2016 | 09:22 AM
wdbarr's Avatar
2011 E63 AMG
Too late. Got the 2011.
These things are insane.
Old Nov 7, 2016 | 09:52 AM
I agree totally. Love the "Beast".
Old Nov 21, 2016 | 02:52 AM
dinman's Avatar
Most of them
weird you say that, i just pulled my glovebox out a few weeks ago and fixed mine.
Good luck. you'll love it. i've had mine since january and have replaced the voltage regulator, battery, serpentine belt, and tires.
Old Nov 21, 2016 | 07:29 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
Forgot to respond to this when I saw it. Is it because of the traction caused by the passenger door pulling on it when fully opened? Does that mean not having the passenger side front door opened fully too many times will prevent that?
