2014s Intercooler replacement and Bleeding
I have never seen some many cooler on a car to date...WOW..
1. Completely fill the system, just below the level of the resevoir return hose.
2. Pull the return hose off the plastic fluid resevoir.
3. Put the end of the hose you pulled off the resevoir in a cup to catch the fluid.
4. Put your thumb over the return nipple on the rear of the resevoir.
5. put your mouth over the top cap opening of the resevoir and blow hard.
6. It will force the fluid though the system and up into the cup getting all the air out of the system.
1 Large engine radiator
2 same size turbo cooler
3 AC condensor
4 2 coolers totaling the radiator size 1 for oil and 1 for trans
5 two cooler by the wheels...
Problem is the dealer said it is not on the american system and the german system is down....
This car has 3 water coolers, one oil cooler, one trans cooler,A/C and radiator... The front of this car is nothing but coolers...On the other hand my w211 e63 was a puzzle up front....
