2010 e63 MCT Issue?
Old Mar 1, 2017 | 05:13 PM
The1stWright's Avatar
2014 E63S
2010 e63 MCT Issue?
Figured I'd try the forums first to help me out, recently I've noticed at WOT the car has a moment of hesitation from 3rd to 4th, it almost feels as if somebody is lazy on the gear changes on a manual transmission.
I'm assuming it's either the clutch packs or conductor plate. Could it be anything else?
Old Mar 3, 2017 | 03:39 AM
Celicasaur's Avatar
W212 - E63 AMG
Lazy, but does the engagement feel like it throws you in? SMG gearboxes do this when the pump/solenoids are failing. My MCT used to feel ever so slightly sluggish on the upshifts and a bit uncomfortable at times on the downshifts (mainly 3rd to 2nd and 2nd to 1st), but after valvebody solenoid replacement (8 of them, 2 of which were failing), my MCT behaves as normal now, ie fast on the upshifts and comfortable on the downshifts. The repair cost around £1200GBP in Nov/Dec 2015 using MB parts but not fitted at Mercedes. Hope that helps.
Old Mar 3, 2017 | 09:55 AM
2014 E63S
Thanks for your response, it's a weird sensation, it's almost like being at WOT with a manual but somebody is shifting from 3rd to 4th extremely slow.
Old Mar 3, 2017 | 10:42 AM
LJMartin's Avatar
2010 E63 AMG
I just took mine in for slow shifting problems and the said I had a intake manifold leak.
Old Mar 3, 2017 | 04:04 PM
xheamgbenz's Avatar
W203 C32 AMG...W221 S63...SOLD...W212 E63 CURRENT
Check the intake manifold first and make the dealer update the tcm and do the adaptation how manny miles do u have in yours
Old Mar 6, 2017 | 06:18 PM
LJMartin's Avatar
2010 E63 AMG
Thought I would share an update on my 2010 E63. When they told me that the car had a intake leak that might have been causing the slow clunky shifting in starting from a stop in comfort mode, I thought they meant that an intake gasket had failed. Today I was informed that the intake manifold had cracked and had to be replaced. My SA said they had received a bulletin on the problem. After replacing the manifold it still failed to pass the test and they didn't know what to do so they started a tech ticket on it. Said it may be the valve bodies or they may have to replace the tranny.
Old Mar 6, 2017 | 06:26 PM
PeterUbers's Avatar
is this car under warranty?
Old Mar 6, 2017 | 08:35 PM
LJMartin's Avatar
2010 E63 AMG
I took it in on march 1. My factory extended warranty ran out March 3.
