Heat exchange problems
Old Mar 16, 2017 | 12:04 AM
jrosa's Avatar
C63 S AMG 2016
I was talking today to some petrolhead friends about changing the downpipes of my car, but one of my friends told me that the E63 had a chronic engine heat problem, and that I should upgrade my car's heat exchange system prior to any change of downpipes or any other upgrade, specially because I live in Rio de Janeiro, Brazil, a place with very warm climate, with temperatures easily reaching above 110°F during the summer, a winter (if we can call it a winter) which last for 72 yours only, and temperatures staying around mid to high 80s F during the rest of the year.
Any thoughts about all that?
With all your previous experiences with E63AMGs does our cars really have this chronic heat problem?
Thanks!
JC
Old Mar 16, 2017 | 12:06 AM
Amg63-'s Avatar
CLS63 AMG
I think year 13+ Have split cooling from factory to help with that
Old Mar 16, 2017 | 12:25 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Yes, we have an inefficient charge air cooling system. Instead of spending way too much chasing minimal results upgrading my the heat exchanger, you're better off adding a water/meth injection kit to reduce intake air temps.
Old Mar 16, 2017 | 12:33 AM
Amg63-'s Avatar
CLS63 AMG
do all year models have this inefficiency? Why would they never correct this
Old Mar 16, 2017 | 12:50 AM
chiromikey's Avatar
14-16 are improved but they've been vastly inefficient since 03.
Old Mar 16, 2017 | 10:03 AM
KLR CLS's Avatar
CLS63 PP
All Liquid to Air IC's suffer from the same issues with heat soak. They are generally more efficient that Air to Air under low load/speed conditions, but once the coolant is hot ( ie heat soak) they are troublesome. While 13+ cars have a split system ( one that is divorced from engine cooling loop) they have the same heat exchanger size and pump. The only ways to solve Liquid heat soak are:
1. More system coolant volume and circulation capacity. Adding secondary coolant tank, increasing plumbing diameter, and higher volume pump feeding a bigger HX.
2. Active cooling like a killer chiller that using AC system to cool a liquid/liquid HX core
Now like chiromikey said, the goal is really to reduce IAT. For high load, or racing conditions, Meth is the only answer for that.
Bottom line for op, Upgrading Intercooler circuit via the above methods will help in 90% of the daily conditions you will see in Brazil, but under high loads/racing meth is the only answer. If you can do both, your set.
Old Mar 16, 2017 | 11:24 AM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
Thanks!
JC
your climate in rio is similar as mine in miami (i was in rio last year to train at Gordo BJJ in Barra da Tijuca), so you will be fine as you have 2014 like me and I log my car and temp is never a problem for me in daily driving and highway pulls.
you really dont need to worry about cooling on 2014+s unless you are going to a race course and race it hard for long time, or if you are going to drag strip and running lots of back to back runs.... but in daily driving or street racing runs you will be fine
Old Mar 16, 2017 | 11:28 AM
Amg63-'s Avatar
CLS63 AMG
is there any difference in cooling from 13' to 14+?
also, does extra power from a tune make it heatsoak faster than stock?
Old Mar 16, 2017 | 11:43 AM
gaspam's Avatar
from what i remember reading, 2014+ S model gets additional cooling small radiator on the drivers side of the bumper
yes adding power adds heat and makes cars heatsoak faster
Old Mar 16, 2017 | 12:56 PM
kponti's Avatar
E63
Or get the AMS cooling system and make multiple pulls on the dyno in 80-100 degree ambient with zero heat soak (Eurocharged was impressed)
Old Mar 16, 2017 | 02:34 PM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
You could also go for a trunk tank setup, which will allow you to add ice into the system.
Available Here
Old Mar 16, 2017 | 03:53 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Glad you like the system.
Old Mar 16, 2017 | 04:12 PM
chiromikey's Avatar
It's a nice kit but for 1/6 the price and better cooling I think meth is the way to go (as long as you don't mind the periodic fill ups).
Old Mar 16, 2017 | 04:34 PM
shardul's Avatar
Meth is good but the cost will creep up if you use quality components such as braided lines, solenoids etc. Granted it will be still less expensive than the AMS cooling pkg.
