figured i would throw this out here since i couldnt find and threads on this and had to take a shot in the dark for compatible part numbers for driver side (left) door mirror and cover assembly as mine got smashed few weeks back from truck on highway that hit as construction cone and flung it up in the air, which ended up hitting my door mirror and destroyed it
the mirror assembly is basically 3 structures : 1.) the arm (which holds the motor and electronics/ blinker/ night pkg lights) that attaches to door 2.) the mirror that snaps onto the motor and 3.) the cover/shell that goes over all the internals.
on mine, the arm/ internals was fine, just the shell/cover and mirror got destroyed so i went searching for those parts... cheapest i found was parts.com and for mirror is 2048103121 for $637.20 and for cover part is 2128101115 for $755.20 , so $1392.40 total
so started searching online and found that euro spec parts from 2011+ would work on my 2014 and look exactly the same! ended up getting the cover new for $161 from ECS (part 21281067009197) and got the mirror used from ebay russia for $89 (part 2128102221)... so $250 total
so saved $1142.40 by using those parts instead.... install was a no brainer... just pop cover on (it has a electrical connection you have to line up with the arm piece and then pop the mirror on the motor (circle plastic piece) and start up the car and you will get a few mirror/ turn signal/ blindspot assist error messages... turn the car off and start it up again and messages go away and you are finished
