need some advice on Throttle lag and clunky gear change issues.
Old Mar 26, 2018 | 04:08 PM
E63_u_mirin's Avatar
E63
when the car is cold there is a lot of throttle lag and clunky gear changes (up shift and also down shift)
when the car is warm the throttle response is better but when I come to a full stop at a red and then get back on the accelerator it jerks into gear.
and this is all happening in Comfort mode...
Is this a transmission issue ? or a software update issue ?
and its a 2010 E63
thanks guys.
Old Mar 26, 2018 | 06:44 PM
PeterUbers's Avatar
Did the car go from driving normal to driving like this ... did you just acquire this used car?
Old Mar 26, 2018 | 07:23 PM
E63
I've owned the car for 4 years. It has always had some throttle lag on a cold start, but recently has gotten noticeably worse.
Its like the transmission/clutch is not engaging right away and when at a full stop it seems to go into neutral and then hard shifts back into gear once you accelerate.
not sure if its tranny or software related...
Old Mar 26, 2018 | 07:39 PM
PeterUbers's Avatar
unlikely software then, more likely bad clutch or clutch needs a re-adaptation
or... bad valve body
Old Mar 27, 2018 | 04:25 PM
E63
sounds pricey... fuarrk
