New to me E63s
2014 E63s
Bought a 20k mile E63s in January 2018. Finally got it on my son-in-law's dyno. I was a little surprised at the numbers as this dyno is pretty accurate and is used to certify local NASA race cars. He also tunes cars for the Pikes Peak Hillclimb. Planning to get a Kleeman tune here in the near future so should be a good comparison.
Stock 2014 E63s on Dynojet dyno.
OP - congrats
many times sellers don't disclose tuning to the ecu and you can pop the edu and check to see if it has a drill hole on it's bottom ... my understanding is that drilling the ecu bottom plate is a requirement to tune the m157
you can also have a tuner look at the ecu to determine if it's got an oem tune or aftermarket tune
my thoughts exactly
OP - congrats
Finally dynoed the car again after the tune. Picked up a lot of low end torque, not much above 5500 though. Seems turbos are pretty tapped out at higher RPM. But mid range torque is amazing. Yes these are corrected numbers to sea level based on an altitude of 5900 ft. Uncorrected numbers after tune are 501 rwhp and 656 rwtq. Tune cost $2200. If I used the sea level numbers and then added in Renntech's generous 17% drivetrain loss, the crank numbers would be 737 crank hp and 965 crank tq. For comparison, the original factory numbers are included so you can see the difference between stock and tuned. The dyno operator slowly opened the throttle until full throttle at 3500 rpm. May have made more torque down low but a sudden dramatic increase in torque is pretty hard on the car and dyno.
