Plug life....
Old Jul 2, 2018 | 03:15 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Plug life....
Seeing the thread yesterday on plug replacement made me think....should I replace mine based on age?
She is a 2012--6 years old--but just turned 31k miles. Of course, it does get stupid hot down here. I don't have any issues, fires on the first twist (push) and makes good power. My car is pretty close to stock...modified box and resonator delete.
So, if I need them--and I'm not sure I do--use the OE or...? I went to the one step colder plug in my e55 and it was much happier, but it had Renntech pullies, injectors, and software. Perhaps the moneyh is better spent update the cooling. Thanks for your answers in advance...
Old Jul 2, 2018 | 06:49 PM
g60wall's Avatar
2014 E63s
Oem plugs gapped to .022, I am tuned. I change them every 15-20k. OEM plugs are all you need!
Old Jul 3, 2018 | 06:46 AM
rocky raccoon's Avatar
W123 300CD, R107 560SL, W211 E320
You may already be in trouble. Leaving spark plugs threaded into the cylinder head for so long, regardless of miles, can almost guarantee that they are seized in place. I would have them replaced very soon.
Old Jul 3, 2018 | 10:08 AM
T_Cob's Avatar
2012 E63 AMG PP
I have a 2012 and did the spark plugs when i did my tune around 25K miles. None of them were stuck but i would order all new boots. I broke six of them trying to get them out. Also get some di-electric grease for the new boots.
Old Jul 3, 2018 | 10:47 AM
allenjdmb's Avatar
Did you go...
Back with oe plugs, or another brand or heat range?
Old Jul 3, 2018 | 11:15 AM
T_Cob's Avatar
2012 E63 AMG PP
I went OE plugs. The part number has been updated to the newer plugs. If you are tuned I would go with a smaller Gap. There are a ton of threads about spark plug gap with tune.
Old Jul 4, 2018 | 07:59 AM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
Just replaced mine @ 33K not sure if they had been done before but were pretty tired and the car runs smoother since i did it.
Old Jul 7, 2018 | 02:35 AM
vdubpower's Avatar
i drive them all, fast and hard
oh snap, im at 6 yrs 53000 miles bone stock and never done plugs
stupid me for going by dealer service schedule...they never mentioned doing them so i havent...
car has been fine as far as i can tell... and ive had it since day 1
Old Dec 31, 2018 | 06:30 PM
kponti's Avatar
E63
What do you guys think of this plug?
Bosch ZR6SII3320
Old Jan 1, 2019 | 10:55 PM
amg_w211's Avatar
2014 E63 AMG S, 4Runner
Originally Posted by kponti
What do you guys think of this plug?Bosch ZR6SII3320
I've looking getting a Eurocharged tune and I've been researching spark plugs. Those Bosch ZR6SII3320 are the OEM plugs (Bosch heat range 6) for the W212 E63 M157. From what I can tell based on chart cross-references, alternative plugs you can use are the Denso 3495 (FXU22HR11; Denso heat range 22) which is 1 step colder or the NGK 97506 (SILZKBR8D8S; NGK heat range 8) which is 2 steps colder than the Bosch plugs. All of the above plugs are 'long-life" iridium plugs (they are constructed of either double iridium (Bosch) or iridium/platinum (Denso/NGK) center electrode/ground electrode combinations).
All manufacturers use different heat range ratings, but the cross-reference chart helps determine the correct heat ranges of each spark plug offering.
https://www.briskusa.com/spark_plug_...at_range_chart
