2014 E63s Engine Oil leak
2014 E63s 1993 mazda rx7 on Boost
I noticed an oil leak on driver side above the AC compressor. It is not from removing the filter or filter cap o-ring as that area is totally dry.
Seem to be coming from what is above the AC compressor switch, as the switch wire was wet. I clean everything and hoping I can narrow it down.
It their a MB website like the BMW Realorm.com site... love that BMW site...
BTW I went with Liqui Molt LM 2332..
Thank You all for for any pointers.
I did have the dealer change my cam tension adjusters when it made the rattle at start up.
Wondering if they did a poor sealing of the plate. I just did a V8 BMW front plate so it is not new to me but this would take more time for sure.
Moly seem to have quiet the motor down and lower my oil temps some. Water is always 199 and oil 207 -213..hard driving 225 -229 but would never return to normal with M1 oil. With the LM the oil temps go back to around 208-210 faster but is always closer to the water temp with LM
Liqui Moly
