Big Brake Kit Upgrade (cheaper then stock)
00 C200 & 00 C55 & 06 SLK55
If i'm not mistaken; 2010-2015 "Sls" (C197/R197) also sharing the same offset with all "55's/63's":-
which is (64.5mm), with (390mm) Front Rotor, code: "-B07",,
except (SGL/CCB):-
which is (58.5) with (402mm) Front Rotor, code: "B07+P98"..![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
-;ZAYED;-
except (SGL/CCB):-
-;ZAYED;-
Just did some breaking testing I have to say I am super happy with it is a big improvement over stock in really didnt think it will be this much better just by going 30 mm bigger and I am using trw pads.
The following 2 users liked this post by b0kix:
507monster (10-18-2019),
a100steaksauce (12-20-2019)
#32
So if I can buy the bracket separately. I can purchase the giro disc 390 mm rotors and it should fit since offset has been said to be the same for Sls and e63
#34
#36
But we can agree the giro disc not only look pretty the Are pounds lighter then factory 2 piece. So if I can increase size and still save weight per corner that’s a win
#38
the 2pc 390mm brembo are the same weight as oem 1 pc.
I an just now big fan of the slided rotors, I like the cross drill look better. which slided are better for track and heat.
CerBErusM113 (01-24-2019)
#40
https://www.girodisc.com/Girodisc-Fr...MG_p_6594.html. Shows they are 1400 for 2. Definitely more money then brembo. But we all knew that. Also the 360mm rotors from giro disc are 14.4 pounds compared to what the oem are. I’m assuming the 390mm weigh more but not a significant amount more. I’m thinking a lb or 2 more. Which still seems a couple pounds lighter.
#41
#49
Received 2,032 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
