Engine swap help
thanks
thanks
Can you share more specifics on what exactly was involved with “blowing up your engine”?
I am just wondering if bottom end failures on the 156 is more common than MB would like us to believe.
As I recall, you can likely find decent used motor from a wrecking yard for between $6k and $12k depending on miles.
Good luck man. It sucks to go through this.
