TCU reset brings boost back
Received 2,076 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
the aux nothing to do with ecu you are correct; and you are wise not to unplug that
i actually disconnected both to be sure there was no information left. After 45 min I plugged all back up and to my surprise I still have radio and seat memory. I was confused
I personally feel as if completely restored what I remember the power and tq feeling like when I first received my stage 2 tune. Haven’t went back to track but I’m confident there will be a difference. My head is planted to headrest again. So I can’t really say if it returns boost. What I feel it is , it’s timing which goes hand and hand with boost onset. After summer days of 100 degree weather, then winter back to summer I’m sure timing adjust and adapts, maybe we are just restoring it back to the beginning of the learning curve
Battery disconnect to reset ECU adaptions has and will always be a myth.. Regardless, they are adaptions, they will always adapt where they were originally were unless hardware was changed or something other was modified. Adaptions are usually ONLY reset via software resetting, via something like XENTRY.
I have up and running HP tuners datalogging, once i get some logs in, i will make a new thread i think will be priceless for us tuned guys and non tuned guys of course, to see our boost levels and parameters for cases like this.
#32
Battery disconnect to reset adaptions has and will always be a myth.. Regardless, they are adaptions, they will always adapt where they were originally were unless hardware was changed or something other was modified. Adaptions are usually ONLY reset via software resetting.
This is in direct contradiction to what you wrote above. You said pedal dance was a myth and the battery reset works. 5soko here is claiming battery disconnect is also a myth.
What should we believe here?
#33
MB does specify to not reset any ECU adaptions like Short term fuel trims or long term fuel trims, etc unless a repair is being made aswell.
Anyone who has reset hard ECU adaptions, knows how poorly the cars run until the ecu and sensors have adapted to its normal running range.
#34
Lol, yeah he's wrong. I could sit here and type for an hour and a half explaining why but I honestly don't care. I'm a shop foreman at a Benz dealer and was the lead diagnostic tech at my previous dealer. I don't know everything but I've literally done these "resets" countless times and verified everything I've said. But hey, what do I know......
The following 2 users liked this post by mbmastertech:
altesporsche (11-15-2022),
thxrick (12-13-2018)
#35
[QUOTE=5soko;7629015]MB does specify to not reset any ECU adaptions
Lol.....wrong.
You can't be serious!
Lol.....wrong.
jvakos (12-13-2018)
#36
Once i have time i can check this out for everyone here using my Mp2 interface to be completely clear.
The only time Mercedes mentions doing any type of adaptation is when install a new ecu, this is via WIS.
#37
I would love to talk more and to know more... What exact adaptation does a battery disconnect reset? ECU adaptations like STFT, LTFT,MAF, MAP, etc are part of data in the ecu and does not get reset from a power disruption.
![](https://farm5.staticflickr.com/4804/44489652860_5390987685_z.jpg)
image1 (1) by 5soko, on Flickr
![](https://farm5.staticflickr.com/4905/46306345491_201165d5f5_z.jpg)
image1 (2) by 5soko, on Flickr
Anyways it was nice talking with you guys. Mercedes has the best cars in the world. You all should be very proud of your hard work that's led you to be able to own one. Some people are stuck driving regular boring Fords, Chevy's and Honda's. Have a great holiday everyone!
#38
Dude, there is way way too much information for me to explain everything to you. Disconnecting the battery DOES reset numerous values including: mixture adaptations for short term, long term, idle speed mixture adaptations, lower and upper partial load mixtures which combined change full load mixture adaptations. It also resets crankshaft sensor adaptations, lambda adaptations, throttle valve adaptations. That's all in the engine ecu, in the trans it resets the fill time and pressure adaptations, lockup clutch adaptations and wet clutch adaptations. The screenshot is the menu path that needs to be selected to go through a proper initial startup of the engine control unit lol! When using xentry you need to click on "engine control unit," then click on "control unit adaptations" to get to the learning process after you have replaced the ecu. You can believe what you want but don't confuse people with incorrect statements. Control unit resets are very very common with Mercedes, and that 100% includes battery disconnects! Anyone who works on these cars or any luxury car brand for a living knows that.
Im sorry, but all of the adaptation you mentioned are all only reset via xentry, not a battery pull.. My LTFT is a 0.6.. so if i pull the battery this should resort to 0.0 correct? I believe this is a very easy and simple way to prove this theory? I can do this all in one video live.
If you have tried resetting most of these adaptations via Xentry on the M157, you will see there is a difference in car behavior vs a battery pull as the sensors are adapting from i.e. Zero.
Back to the OP's question:
Boost... Wastegate Controlled by vacuum solenoid via ECU. ECU bases boost off of load ( and another map) via the RPM, IAT, throttle, MAP pre and post throttle valve, both intakes sensors, knock etc. Removing any boost leak from the equation, if your code scanning isnt bringing up any codes, i would get a boost gauge or logger to confirm boost is not hitting its target or send the ecu back to the tuner. Unless any of the above is out of order, IAT's way too high, igntion being pulled, MAF's not reading correctly, or clogged filters, etc, boost should be consistent for the most part. Battery pull, shouldn't effect this, and for those who believe it might, adaptions reset will only return back to their adapted state after some running time. (no changes to hardware otherwise)
#40
Disconnected my battery for 30 minutes then drove for two days. COMPLETE difference in how my trans shifts. Anyone who claims this doesn't do anything is talking out their behind, with all due respect. The hard/jumpy shifts I always got in S mode and frequently got in S+ mode from low speeds are now gone. For now at least... perhaps the trans/ECU will regain its "bad habits" over time since I have a lead foot. But we'll see.
#41
Btw, i forgot to mention this, i write program for mercedes amg
#42
haha! Just because you have software to modify the oem tune on your own car doesn't mean you know what you are doing. Lots of people can "wite" programs to ECU's lol! Please stop trying to make people think you are special. Typical Mr know it all. Fact is you have been wrong a lot on this forum. I feel bad for anyone that believes what you say. Unfortunately people like you are what ruins these forums.
#43
stop lying to people about what you know and backing it up with you work at dealer, like that end the conversation lol that gives you no cred... show us proof, show us documentation?? This you wont provide because you cant.
I was trying to be nice and have a good conversation, im not sure why you got so bent out of shape because i challeneged what you said, really no room for attitudes like yours on this forum. You are going to have guys disconnecting their batteries for no reason and end up damaging components. If you were a true good tech, you wouldnt advise your customers to do this since you know the car will go back to its oringinal state before the battery was disconnecting anyways, and you should know resettinf adaptations is a bandaid, not a solution to any hardware problem.
#44
Its a forum, a place for debate, your so hostile and angry because you want to be right.. Your username just shows how bad you want to be right.. your a dealer tech (maybe), you do what WIS tells u. Thats as far as your knowledge goes lol
Lol! You are too funny. I don't even know where to begin with all the nonsense you are writing. This topic is going nowhere so let's just agree to disagree. I have no need to prove who I am in the world of Mercedes. Especially to some random nobody on a forum like yourself. Maybe focus on "writing" the program for your amg lol. If you can't even grasp the reasons behind battery disconnects then I hope to god you don't sell your corrupt tunes to others. I'm sure you will be on here needing an engine someday. "Btw I forgot to mention I write programs to amg" LMAO! Funniest post I've ever seen here!
#45
#46
Battery disconnects do reset most adaptations including short term and long term fuel trims. Do not underestimate how fast it takes to get those trims adapted back again after a restart, however it may not go back to the original values right after a restart.
yes I have seen those values change after a reset
#47
Is an ecu pull the same as at a negative terminal pull?
in terms of the performance gains that is....
#48
Now I am only speaking to matters that pertain to the ECU. Pulling the ECU does not disconnect TCU in any manner. Of course I am assuming that the TCU and ECU are separate components. I am not actually certain of that. Again though, assuming they are, then pulling ECU will not affect trans performance.
I have personally pulled ECU, without disconnecting anything and then reconnected it and witnessed adaptation resets.
#49
It absolutely should be! Simple electronics. Pulling the ECU disconnects power. Disconnecting negative terminal opens the circuit and is disconnecting power.
Have you ever seen a tuner pull battery after taking your ECU in and out of the car? Even after loading a whole new tune.
#50
