Whats up with these remote batteries???
Received 1,491 Likes
Never had a single issue with my silver '14.
but with my new red '16 was having constant low battery warnings and a few "no fob detected"errors.
I ordered a bunch of cheap knockoff 2025 from Amazon... Each seemed to last a week.
I did two things to fix mine.
First gentle pry the 4 prongs up slightly. I found they get smashed down over time losing contact with the battery.
2. Clean all the metal contacts with a q-tip and 91% iso.
3 use a brand name battery, I bought a 10 pack of energizers
Since this, I haven't had one error in the last 60 days
I have had my '14 ~5 yrs now. Gone through ~4-5 batteries. I barely drive the car and the key is kept two floor above the car. The only key fob I changed a battery in was from my old Sienna; once in almost 6 yrs, and that car was driven daily.
Received 2,037 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Does anyone know if the keyfob uses up more energy (drains the battery more) if it's the daily use key fob vs being stored in foil (dormant) or in a distant location? In other words once the keyfob has engaged with the active vehicle is it sending more signals during the drive than the dormant keyfob?
I.T. Guy (01-21-2023)
@1MavRick Excellent! I know that screen well...
I took some time today to take some data.
- New batteries from Amazon (from www.licb-battery.com, according to the package) - tested three of them, they all came in at 3.26V
- The last one I took out of the remote after getting the screen above: 2.99V
- The one I replaced with (last week sometime) 3.11V
- The one in the other remote (that seems to be working longer ) 3.01V
So the new one is half way from new to 3.0V in about a week, but could be about ready to start misbehaving. I guess I will use these up (I got 10 of them...), keep taking data to see if it appears to be a battery issue, or a remote issue. It sure seems like these are crap batteries, though
The following 2 users liked this post by knowbenz:
JimFE (01-23-2023),
Johnny Rad (04-22-2023)
#33
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Have only replaced a battery in one of my FOBs, probably 3 years ago (DD in the winter). The 2nd FOB is still on the battery that came with the car (bought in 2017).
The back up key sits in a drawer by the door to the garage.
The daily driver key hangs on a key rack that is beside the door to the garage, so probably less than 10 feet from the car.
No idea why some people can go years, and others just a few months.
#34
I am going on 3yrs with my batteries on both remotes. Still work fine. I live in a condo complex and I stay on the top floor and car is in the garage basement underground where even cell reception is hit/miss
cotmfk (01-23-2023)
#36
I've had the car for about a month, now. When I bought it, the remote battery was dead and needed to be replaced. Which, of course, I did. About 10-14 days later...I get the the 'battery low' warning on the dash. A day or so later...its dead. No problem...bad battery. I install a new one, week before last, and I'm getting the same warning on the dash, today. Obviously, this isnt normal.
Can someone point me to what may be the cause? I'd really appreciate it. I cant go back to the turning the key to start the car life. And I'm not trying to keep a stock of CR2025's on hand, either...
#37
I get the warning messaged every 4-5 months on my primary FOB. In my wife's, for some reason, it's every other month. I last replaced her battery a bit over 6 months ago it's still working, just with the warning screen.
#38
I wonder what role RFI plays in killing the batteries when the keyfob is stored away from the car ... these key fobs are in the 433mhz range I think
#39
#41
Do you take your car to the dealer for service? They change the batteries in the fob when you bring it in and they don't tell you or invoice you for them. I knew they changed mine when there was a different brand battery in them, I had Energizers in them before and I think it was Panasonic afterwards. Also seems to be a difference on whether you have keyless go or not. Both sets of mine are and they last 4-6 months before they drop below 3v and then I change them. I suppose I could probably go longer and see how long it takes before they fully die, but the warning message on the dash about a low battery is annoying so I just change them when that happens.
#42
Back again on this topic. Now the fob will not operate keyless remote, either with the battery I removed at 3.124V or the new one I installed at 3.268 volts. The buttons on the key fob still work (most of the time) and I can start the car with the key, but the keyless options are not working. The second (newer) fob still works fine, as it has for the 15 months I’ve had the car.
I’m guessing there are no “user serviceable parts” other than the battery, and no way to fix one of these things. But if someone else has an idea besides battery quality, I’m all ears. I’d be good with not dropping another several hundred $$ for a new key fob.
Thanks,
Jim
Thanks,
Jim
#43
Thanks,
Jim
Thanks,
Jim
#44
Here’s my experience. Old batteries and super cheap batteries online blow. Buyer beware."...
I have been using the cheap batteries (sunbeam) and I know that is the problem because when I used dealer service and they replace the battery every visit, I never had the signal to replace them. Recommend brand name like Duracell. Gonna go back once these run out.
#45
I have to agre@Johnny Rad "
2013LBCoupe (04-23-2023)
#46
I believe the dealer uses Panasonic. I've tried them before but I tend to get higher voltages from Energizer. Usually there's a few people on eBay who seems to sell lots of them and you get a 10 pack so they're decent. But it can be a gamble. I've gotten some Energizers that were at 3.35 and some that were more like 3.25.
#47
Well it's cheaper if you get at least 5-10 at a time as they still have to pay for shipping even if they offer free shipping which is typically just first class mail. I also have 4 keys, 2 of them take 2 batteries and the other two take 1 so I'm using 6 at a time. They're all keyless go and even though I don't use the other set, the batteries in the other set don't seem to last any longer. When they start getting weak, the keyless go part range tends to go down so I swap them out once they start to get weak.
#48
#49
Thanks,
Jim
Thanks,
Jim
#50
So you have had better experience with Energizers vs Panasonic? I am going to look for a pack on Amazon. They have to be better than the Sunbeam...the replace battery signal comes up just days after replacing. And I have had a really bad experience twice when they have gone dead even after replacing the battery --- the car seems to enter an anti-theft mode... I am going to respond to the earlier post where the fob does not seem to work anymore even after changing the battery.
2013LBCoupe (04-30-2023)
