cut turbo manifold or not? m157 gtx3071gn2
I want to khnow how is your experience about cut exhaust manifols turbo one cylinder. Enyone logs backpressure with and without one cylinder?
I'm afraid that one cylinders will not be work correct. Like petrol engine,not turbo petrol engine. Did enyone logs reatrd ignition with all 10 cylinder when manifold is cut?
TTE900 cut cylinder:
https://tteglobal.com/mercedes-amg/e...mber=SW10082.1
Sorry for my english. Thnx.
If I understand him correctly, I'm guessing he's not able to place his where he can see all 8 (yes, he said 10) equally and was asking if there's concern reading off one runner per side.
Daniel, Not sure what you are looking your backpressure with or if you are using this in conjunction with a custom wired stand alone ecu setup, but by logging backpressure in only one cylinder per side your readings will not be as clean or consistent compared to having tapped where the runners collect below the turbo. Yes. You can just tap into one runner, but given that the sensor has standoff using a tube that should allow you to tap the manifold where you need to.
Hi, you don't understand me.
I ask everyone, is cut manifold turbo or not !!
This engine have a big backpressure when we use big turbo. TTE Cut manifold . But i don't think so it is good way becouse this one cylinder work like Petrol engine not turbo.
this is link:
https://forums.mbclub.co.uk/threads/...pgrade.233030/
