Camber bolts
Hey guys,
Wondering if anyone knows if this is the correct part number for the camber (aka crash) bolts for our cars: 212-333-00-71-64? If so, is it just two on the lower control arms or can we get four and do uppers too? |
I will have to check the parts when i get home, but from what i rememver only cars only have front toe and rear toe that is adjustable.
Hey bud, did you get a chance to double check these? I’d like to order them. Thanks. |
For the rear, I run aftermarket arms and also this allowed me to lower and level the rear. The W212 sits up like a 4x4 stock in the rear.
:) http://ultimatepd.com/amg-w211-e55-t...on-set-70.html |
I do agree with you to an extent. Now, are these all 4 corners? Top two are front lower control arms and the bottom two are the rear lower control arms? I assume the moving plates are to adjust the rear link height to trick the car to lower? Do these reuse the factory hardware? https://cimg7.ibsrv.net/gimg/www.mbw...1269bafb3.jpeg |
