2010 E63 Performance pack?
Old Mar 25, 2019 | 05:30 AM
JoeyAMGe63's Avatar
2010 E63 AMG
Hello all! just joined and am excited to be a part of the community. I have a 2010 E63 as the title suggests and don't know how to tell if it has the performance pack or P30 package. All of the VIN decoders i used didnt say and other than me taking it on the highway and seeing if the limiter stops me at 155mph I'm not sure how else to figure it out. Any suggestions?
Picture of my car included for fun
Old Mar 25, 2019 | 11:29 AM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
If you are able, put the car in neutral and lift the rear end of the car and then spin one of the rear wheels. If the opposite rear wheel spins the same direction you have the LSD which is part of the P30 (performance) package. If the opposite wheel spins the opposite direction, you do not have it.
For WIW, I had a 2011 without the P30 and with fairly inexpensive tune from Eurocharged I had the same horsepower as the the P30. I never really felt I was missing out on much without having the LSD. However, you can always buy a Quaiffe (spelling) aftermarket LSD and have it installed for a total of less than ~$2500.
Hope this helps.
Old Mar 25, 2019 | 07:28 PM
MikeyF's Avatar
2010 e63
Whats your VIN? I'm a salesman for MB, I can look up your build sheet.
Old Mar 26, 2019 | 09:32 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
If not, plenty of aftermarket mods to add I always change my oem plastic idlers out with billet, as the MB idlers fail a lot.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
