Bleeding brakes (CCB), is it DIY?
Is bleeding the brakes a DIY job, can it be done without Xentry? I'm not sure if it matters, but they are carbon ceramic.
Take it back and have them rebleed. To do it properly you will need either xentry or a dealership level diagnostic tool (snapon or matco) with at least the 18.1 or newer update with European models. My Solus is able to work on my w212 and control most (not all) ecu functions including the brake bleeding procedure.
Unless they for some reason had so much brake fluid leave the lines they actually had it exit the ABS unit, and have air enter it. (which is the reason for running Xentyr or similar device. And frankly, most ABS units are actually kind of hard to drain..
