Which Michelins?
Hi All,
Time to replace the PZeros on my 2016 E63. Struggling with the choice between the Pilot Super Sports and the Pilot All Season 3 Plus's. I have dedicated winter tires but kind of like the idea of an A/S tire for several reasons, namely ride comfort and more durability. My question is will I lose a bunch of performance with going the A/S route vs the PSS? I'm ok with losing a little for the trade-offs I've mentioned but don't want to feel a lack of confidence in cornering. Any opinions? |
Originally Posted by MPE430
(Post 7752657)
Hi All,
Thanks for the comments-I don't believe the Pilot P4S are made in our stock sizes-at least I didn't see them listed on TireRack.
Your right ps4s is not in our stock size pss is ur next best bet. I think all seasons are a big waste of money personally. I’d do pss like I just did for mine and when winter comes do dedicated winters.
You can run the PS4S in one width wider, forget the exact numbers. Search for Vrodman - he has a whole thread on it.
And yes - going to all season you will definitely feel it. In general - the stiffer the car and the more power the car has - the bigger the perceived difference. |
You can run PS4S , front 265/35/19 rear 295/30/19
I run AS3+ on mine, replacing PZero's and I'm happy with the choice. Only other tire I would consider is DWS06.
First to consider, does your E63(s) have the wheel and tire protection ( warranty ) package.
If you have the wheel and tire package, you will need to purchase through Mercedes the MO ( none run flat ) or MOE ( run flat ) tires Michelin makes for Mercedes only cars and unless you have either, the wheel and tire protection wouldn’t cover the warranty claim unless you do. PM me with your VIN and I’ll check Monday to see if Michelin has the MO PS4s tires in stock size for your E63. MBusa is running a special right now, if you buy 2 tires, you get $75 off and 4 tires you get $150. https://www.mbusatirecenter.com/ |
I recently switched to PS4S 265/35/19 front and 305/30/19 rear and could not be happier. Summer tires are better in the rain than All-Season tires. All-Season tires are only useful if you see snow or very cold temps.
Originally Posted by Magno
(Post 7752960)
No rub. Stock wheels. Normal looking “bulge.” Diameter is exact match front to rear.
Fronts rub fender liner a little at full lock but only since I lowered the car. |
(Post 7752967)
Originally Posted by S63AMG888
(Post 7752947)
Originally Posted by FastWgn
(Post 7752856)
And yes - going to all season you will definitely feel it. In general - the stiffer the car and the more power the car has - the bigger the perceived difference. Here is the thread he is referring to: https://mbworld.org/forums/w212-amg/...lled-rear.html There is a lot of debate from one particular individual in the thread about the slightly oversized rear tire. I have had the P4s's now for 6 months and I love them. Nope, not tracking the car. But I drive it as spirited as anyone! No problems or issues whatsoever. |
Originally Posted by cmginc
(Post 7752870)
personally liked the pss better than ps4s....quieter
The best thing you can do for better grip handling feel for our cars is stiffen the chassis. Front upper strut bar rear strut bar inside of trunk and undercarriage bars. Our chassis are very soft, that’s why every time some of you go up a slight driveway you hear your pano roof pop or creek. Bars will dramatically improve the handling and make the car more nimble
(Post 7752960)
Thank you sir! LOVE IT! I have a grey wagon as well. Looks like my next rear tire is going to be a 305. WICKED. Thank you.
(Post 7752947)
Originally Posted by taphil
(Post 7813140)
Thanks for the info. Just dropped off my car, getting Michelin PSS to replace the stock P Zeros. Hopefully they’re much better from all that I’ve read. Price isn’t too much higher than tirerack and local installer, but more convenient for me.
ive had both, liked the pss better, quieter, atleast otherwise same
