MCT brake torque technique and implications
Hey folks, I just bought my new-to-me dream car 2014 E63 AMG S wagon and have been absolutely thrilled with it. Happy to join the family here!
For those of you who have had experience using brake-torquing to launch, what's the right technique for the MCT transmission? I've brake-torqued in automatics and understand that it's loading up the torque converter. Since the MCT has a clutch pack instead, is brake torquing similar to burning up the clutch on a manual transmission? Before this car, I drove a 6spd stick so that's scenario I envision when 1) engine is revving, 2) car is trying to move but stopped by an opposite force (brakes in this case).
Is that the correct interpretation? And either way, is brake torquing harmful to the lifespan of the MCT? Thanks!
FYI, in case it matters, the reason I'm asking about this is because I've read that brake-torquing helps with the initial hesitation when trying to take a quick left turn after coming to a complete stop.
Received 1,886 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
amgwagonne (05-15-2019)
Use LC if you can and minimize brake torquing
C63 W204 / E63S W212 / E63S W212
Its not good for the Wet start up clutch or other clutch packs, i believe the tcu doesnt fully pressurize the clutch packs when engaging the LC untill you let go of the brake. Now with brake-torquing the tcu fully pressurizes the clutch pack thinking youre trying to take off and therefore putting higher levels of stress on the whole transmission. Brake-torquing may lead to clutch slipping sooner. Also the AWD is already harder on the tranny out of the box, because the tires cant slip, the tranny has to digest all the power.
And try the sprint booster
With proper and warmed up tires a stock e63s wont spin on any decent surface and definitely wont leave stripes. Lol i wanna see someone leave stripes from a launch with ps4s’s with a stock e63s. Considering we have a tcu that limits tq early on, i dont really see it happening. No matter what the scenario is, awd is always gonna spin alot less than rwd.
If you read carefully i mentioned “out of the box”, if you dont know what that means i can translate. Or try at least. Yes they replace rear tires sooner because its 33/67 split lol, now guess why the rear would wear out sooner? Maybe your car uses rocket fuel we wouldnt know.
FYI, My E63 will spin the tires on pump gas ( 93 octane ) here where I am. I would be scared to use rocket fuel, it may just fly away.
Yes, I understood. I added "I am tuned" to show I had carefully read you reply. I might also contend that, a 'Stock' E63 may spin the rear tires. The 33/67 split would make it even more possible as the fronts do little work. The amount of tire spin may be minimal however present, thus the extra wear in the rear tires. After all even an "Stock" E63s has what 577 tq? Not a huge stretch to believe a little slippage is possible.
Thanks and good day/evening.
Brake boosting with traction off is the best way to launch the car.....will it put wear on the clutchpakcs and tranny..Im sure but after 500plus launches and 759whp 800+whtq still no problems 💪
Launch control on this car will cause less wear IMHO.
not saying that LC doesnt put strain or wear on the car, but it is programmed to do so in a smooth and controlled manner via the tcu software.
brake tq i can see putting alot of pressure and strain on the start up wet clutches, i wouldnt hold that brake tq stance for long, more pressure and heat build up on the whole deivetrain. A quick brake tq release is prob ideal.
End of the day, neither will yeild anything dramatic since the tcu cuts tq regardless
E63 SL55 996TT C5Z06
when you brake boost what RPM do you launch at? I can’t seem to get it above 2500-2800 with brake boost and traction full off? Race start goes 4K RPM and launches consistently but I’ve never hit better than 1.9 sec 60ft time on race start (tested on **** chicsgo roads do maybe that’s my problem )
That’s awesome 759whp what tune / mods you running?
Aa far as the mods Eurocharged custom tune pure turbo stg2 catless dps udp intake spacers no resonators and ice tank in the trunk.
If I give heavy throttle with the foot on the brake the car stumbles at about 1200rpm and wont rev higher.
If I give light throttle the RPMs go up and then come back down when this happens then I can give more throttle and go up to 1500, 2000, 2500 rpm etc depending on how much throttle I give.
I have never given full throttle with the brakes on, I just assumed something would snap. Do you hit the brake and mash the throttle or do you hold part throttle first and then give Full Throttle?
