M157 Intercooler Pump
Old May 23, 2019 | 04:25 PM
Siegmann's Avatar
10-second E550
Is the Bosch "010" pump the factory intercooler pump on the M157? Looking to upgrade an M278 IC pump.
Old May 24, 2019 | 09:59 AM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
do you have a tune
if you add a tune they can increase pump flow unless you have a failing pump.
https://www.fcpeuro.com/products/mer...ump-0392022010
Old May 24, 2019 | 03:30 PM
Siegmann's Avatar
10-second E550
I will be tuning it and can crank up the pump speed, but would like to upgrade soon so that it's not running near full capacity.
Old May 24, 2019 | 06:23 PM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
Look up Pierburg MK1 70675405
That's the one i m using.
Make sure you modify power connector too.
