Losing Intercooler coolant
Old Jun 24, 2019 | 06:05 AM
Roverron's Avatar
ML63
Are these car known to lose intercooler coolant it seems I keep having to add fluid.
Old Jun 24, 2019 | 11:12 AM
timm206's Avatar
C63 W204 / E63S W212 / E63S W212
Which year is the car? If facelift then it could be a rock damage to auxillary heat exchanger, ones for engine coolant ones for IC coolant. If tuned could be a leaking intercooler, they are known to leak after certain boost levels. Or piping.
Old Jun 24, 2019 | 12:34 PM
Roverron's Avatar
ML63
2014 ML63
It’s a 2014 ml63 I will have to start looking harder I already did a general scan looking for leaks or wet spots. I’ll look harder now
Old Jun 24, 2019 | 01:01 PM
timm206's Avatar
Try taking the splash shields off to have a better look. No aux heat exchangers on ml63 seems like so thats out of the equation. Good luck.
Old Jun 25, 2019 | 12:23 PM
PeterUbers's Avatar
Lay some pieces of large white posterboard on the garage floor and park over it
Old Jun 25, 2019 | 11:27 PM
e65's Avatar
e65
2014 E63 S model
It may be boiling out of your cap, landing on the hot V and evaporating. Look for orange residue on the hot V or around the cap. if you do a hard run open the hood and look and see if the cap area is wet.
Old Jun 28, 2019 | 01:29 PM
nyc_amg's Avatar
2018 E63S AMG
Also check the coolant reservoir in the center of the motor, take the engine cover off, make sure that is topped off as well.
