Data logging (and data loggers)
Old Jul 22, 2019 | 08:38 AM
cij911's Avatar
one car at a time
Folks, I am looking for a new method of logging boost, IAT, timing , knock, etc. In the past I have used Innovate (did not like), I just bought the new Kiwi 4 (their app keeps crashing and can't find one that works), Zeitronix (I used on the Evo that was amazing and could have fail safes programmed), and then the best of course open source like EvoScan,,,,,
Anyway, I would like to start logging my stock e63. Any recommendations? Thanks
Old Jul 22, 2019 | 11:07 AM
5soko's Avatar
AMG
HP tuners MPV2 obd with their VCM scanner, is the datalog software and hardware i use.
i have tried a bunch of obd loggers and they are all horrible. Benz world of logging is a slow paced and quiet area.
but this software works great, multiple parameters and doesn't freeze or crash.
Its 300$ but works well and worth the money.
Old Jul 22, 2019 | 08:51 PM
cij911's Avatar
one car at a time
Agreed with the poor options on the MB platform. What is the HP Tuners "pro version" and is it worth it? I am hoping the HP Tuners MPV2 allows you to log locally and then review on a PC / Mac? How does the standard version connect to a PC (and will it work with a Mac)? Thanks
Old Jul 22, 2019 | 09:45 PM
5soko's Avatar
AMG
This is what you want, 300$ The other stuff is if you want to tune yourself and edit the DME files.
https://www.hptuners.com/mpvi2/
You use their VCM scanner software which you download.. 300$ gets you their OBD plugin and cable to connect to your PC via USB.
I use it on PC, im not sure if it works on mac. You log when your computer connect, press record and you preset all the parameters you want before hand, save the datalog when your done, and you can review and graph it afterwards, etc.
Here is a graphed version of my datalog using HP tuners, RPM, THROTTLE, BOOST, IGN TIMING..
You can datalog, IAT's, oil ,coolant temps, Knock retard per cylinder, Wastegate duty cycle ( great to check for turbo leaks and turbo health), LT and ST fuel trims , AFR, and Fuel rail pressure which ins the 2800PSI level at full throttle.
Boost or manifold pressure, is graphed as ABSOLUTE PSI, so you have to subtract Atmospheric pressure 14.7 from your total boost in the graph to get you GAUGE PSI, which is what we are all used to. My log is a WOT 3rd gear, 4th gear is usually ideal.
My current tune you can see the clean timing with no drop outs, and im peaking at about 17-18PSI tapering to 12PSI by redline.
Of course, ignore everything else besides the WOT pull, hence i added accelerate pedal parameter to the graph.
Old Jul 29, 2019 | 12:02 PM
HPTuners's Avatar
SPONSOR
Mercedes C63 AMG Coupe 507
Hey guys, just to touch on some of the point brought up the Pro version is recommended if you plan on hooking up any analog signals such as a wideband. You can see all of the differences in features here (https://forum.hptuners.com/showthrea...ure-Set-Update) although keep in mind some of them are not available yet.
For now you will need your laptop to do the logging however when the additional features are available for Pro there will be standalone data logging.
Old Jul 29, 2019 | 08:08 PM
cij911's Avatar
one car at a time
I ordered the MPV12 a few days ago and have not received a tracker. Also, tried connecting with a human as to questions regarding the Pro version, which proved impossible.
If we have an Innovate wideband, how does the Pro version connect? If it doesn't or doesn't easily, which sidebands work well with the MPV12?
Finally, does the MPV12 work with Apple OS?
Old Jul 30, 2019 | 08:35 AM
Savage212's Avatar
2014 E63 AMG wagon
I believe MPV12 only works on Windows based pc's. There may be a way to emulate windows on the mac but I have not done it. My understanding is the MPV12 pro has a extra plug available to add external inputs like the innovate unit.
Old Jul 30, 2019 | 11:38 AM
HPTuners's Avatar
SPONSOR
Did you order it through our website? If so you should get tracking as soon as it ships.
The best way to get in contact with someone is to use to contact tab on our website, I would direct these questions to them and they can give you a detailed answer. https://support.hptuners.com/index.php?/Tickets/Submit
If you still have questions regarding Pro Feature Set check out the link in my previous comment and you will find all of the details on there.
As for Apple OS we do not currently support it, hopefully we can change that in the future. There are some people that have tried running Windows on their Apple device but we do see issues come up with that in some cases.
Old Jul 30, 2019 | 02:05 PM
cij911's Avatar
one car at a time
Yes I did order through your site and yes I did send questions ("comments"). I'd really suggest phone sales / support or selling through a traditional WD model if you want to scale. Since I want to log AFRs, it sounds like the Pro version would be better for me .
Old Jul 30, 2019 | 04:10 PM
HPTuners's Avatar
SPONSOR
We hope to be able to provide phone support in the future however we are not quite there yet. Our support team is usually fairly responsive over email and if you ever feel that a response it taking a long time feel free to reach out over Facebook messenger with the ticket number and we can check on it for you. You can also provide the order number to see what the status is if you still have not received a tracking number.
