Spacers for my 2013
Spacers for my 2013
So Im gonna keep my stock wheels and love the way they look. Right now I got 285’s out back and 255’s fronts. Im wondering do I
put 5mm spacers out back or 10. Don't want it to rub. I did just order H&R springs for fronts and links out back. What do you guys think?
I ran 8mm front and 10mm rear last winter with my stockers in my '14. No issues and my car is also lowered. I bet one can run 10mm F and 12mm R w/o problems (W/ stock wheel/tire combo). Just gotta make sure the 10mm you pick up actually work with your F hub (Unless you go with "Lug centric spacers" which I wouldn't advice.)
So you would suggest regular spacers and not hubcentric? I have 285’s outback is that stock or is 275’s stock. The tires are new maybe past owner went up from 275 to 285 not sure.
Your tire specs are stock.
