x pipe or not?
2014 e63 s AMG wagon
x pipe or not?
Hi guys. I just had electronic cutouts installed ahead of my mufflers on my 14 e63s wagon. I was hoping it would be quite a bit louder with the cutouts open but it didn’t do much.
IF I have an x pipe put in place of my factory resonator I have two questions:
(1) will this affect power negatively?
(2) With my cutouts closed (sound routed through mufflers) how much louder will the car be? (Mostly worried about drone)
I have listened to videos and found limited info on forums. Thanks for your input!
Received 2,034 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
PLATINUM SPONSOR
Down pipes will give power and sound. The catback section does not do much. X pipe and resonator delete will change the sound some but if you want cut out sound, then go down pipes.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
what he said - i have an x-pipe / resonate delete on my 14 E63s wagon and cursing is nice - WOT is a head turner and 1st/2nd shift pop/bang noise is oh so nice
