Took my wagon into the dealer yesterday...
Old Aug 16, 2019 | 11:55 AM
Billmiranda's Avatar
2014 E63 S-AMG Wagon
So I took my 2014 E62 AMG-S wagon yesterday because I got the "Drive to workshop without changing gear" message and also because the rear right side is sagging about 1-1.5" and I had a "small leak" error.
I pulled codes as I had to take a day off from work and had 14 errors... most tying back to the A80 ISM.
I get to talk to the dealer this morning and they had zero codes that they could pull up... and they informed me that my compressor was working. Now,.. when I dropped the car off,.. I told them that the compressor was working... but that there seemed to be a small leak somewhere as the car would drop to the ground after sitting a few days. According to them,.. they an't find a problem. I asked if a $100k car leaning to one side is normal ffs. I am concerned that my transmission issue could cause a probelm or leave me stranded on the road... whether they find something wrong or not and also... ffs,... THE CAR IS LOWER ON ONE SIDE.
Is my scanner better than theirs?... obviously it is. I sent them my code pulls and will probably pull another set of codes when I go down there Monday,.. as I'm flying out of town this weekend. How freaking frustrating is it that I go down there with issues that caused me to lose a day's work.. just to be told that they can't find anything.
rant off.
Old Aug 16, 2019 | 06:21 PM
PeterUbers's Avatar
rant off.
Been there, man, rant away.
https://mbworld.org/forums/e-class-w...50-4matic.html
https://mbworld.org/forums/e-class-w...-lovely-6.html
you just don't have a good tech. Take it to another dealer if you're under warranty or a good Indy if you aren't under warranty. Dealers sometimes are dismissive or stupid in their service department.
you definitely have a a leak or airmatic compressor problem or a sensor problem. I had same issue, see my thread:
https://mbworld.org/forums/w212-amg/...-w212-amg.html
