2013 E63 Dyno
So today I decided to go to Original Autosport in Van Nuys, Ca to dyno the car, Dynojet. I have to say I am a bit disappointed with the numbers I did 2 runs. Dyno showed what I was expecting. The car noticeable drops off after 5k rpms when I drive it and it did show just that on the dyno.1st run 545 rwhp and 560 rwtq not sure on the tq rating. Car when warmed up a bit highest run is 552 rwhp and 615 rwtq, only did 2 runs. This was dynoed in 4th gear 91oct. I talked to Matt at HD he says its normal to fall flat like that top end. I don't know what it would've pulled in 5th gear but I doubt it would be much higher then the 552. All I have is Tune, High Flow Filters and Res Delete. The video is the 1st run I had to datalog the second run to send to Matt needed my phones dashcommand to do that so no vid of second run.
Also are you having heat soaking issues? What year is yours? If it’s none S maybe it’s time to split the coolant lines.
If they are not split, it’s something I highly recommend fling soon. (You can check to see if you have a reservoir next to your ECU).
Prettttyyyy sure that’s whp.
https://youtu.be/MA7R-ZyHZWI
This is the only other vid I have. He switches from mph to rpms. I also just did quick screen shot.
Those numbers seem fairly normal for an m157 tune, especially the high rpm whp. Forget about the massive torque that Peter and some others are showing. If you want that, you just have to have the tuner jack up the boost. I think it's largely pointless though since how often are you going to be basically full throttle at 2500-3500rpm without the car downshifting? It seems mainly for bragging rights.
You do have some little dips in the red curve which are kind of weird and may be creating that sense of power drop-off beyond what is normal. Those may be something for the tuner to work out. The blue curve looks smoother although it has lower values.
I dynoed it in 4th does that effect it much as well? Thank you for the help and advice
0-60 & 1/4 mile are also dependent on traction & DA ... again, there are correction factors
Need to do couple 1/4 miles runs, just see if its consistent.
And
Its fun!!!
