ECU tune alone, exhaust is louder? HELP!
I bought my car CPO (used) and only now I found out that it was previously tuned! The dealer did a software update and I thought there was a problem since I noticed significantly less power and less noise. I mean 30-50% more quiet! I no longer get the rumble either.
My car has NO hardware changes, the only difference was the change was the ECU tune was removed. Is it possible that a ECU tune alone will cause the car to be louder? Those with experience, please chime in. I miss how the car felt before as I became really used to it.
I have a 2014 E63S AMG
Unless you had one of those "burble tunes", I don't understand how it can be 30-50 quieter, that makes limited sense.
The good news is that the solution is easy - get a tune!
Otherwise a tune with increased boost can change the tone slightly or if the tuner modifies the wastegate positions.
As Mentioned, time to get a tune!
Do any any of you guys know if any of the off the shelf tunes, renntech, Weistec, eurocharged (?) has this effect. I’m sure boost is increased but not sure about noise. I feel most people get down pipes and other hardware changes with tune so they don’t hear the effect of just the tune. Or would this likely been a custom tune
im also going to call up the tuning shops to see their input. Thanks everyone. It’s hard to go back to a stock car when youve been driving a tuned car thinking it was stock for 30K+ miles
