RPM increase at idle when switching to S+??
Sitting at idle in park, my idle RPM is at 500. As soon as I switch into S+ I notice my RPM goes up to around 850-900 and stays there. This definitely did not happen before the mounts were replaced and I’m wondering if it has anything to do with the mounts.
my SA is out on vacation right now so I can’t contact him to ask if there was a trans software update performed on the vehicle or not.
Is this normal? Anyone else’s vehicle do this? I am 100% sure this did not happen before the mounts were replaced.
tia
Most likely you never paid attention to this prior to the mounts
https://mbworld.org/forums/w212-amg/...servation.html
your 100% isn't so close to 100%
So weird how I never noticed it before. Do you know if it was part of a update on ECU/TCU or was it always there?
I even went so far as to update my stock TCU flash from factory thinking that was the culprit.
I have friend with a 2014 E63S that does in in S+, and another with a 2015 that does it in S and S+.
Drives me nuts not knowing why stuff does what it does.
We all have EC tunes by the way, just different versions.
