Engine mounts
Old Mar 24, 2020 | 05:32 PM
13pp63's Avatar
E63s
Engine mounts
Hey my car has 50 k on it just did tune and dp within a week my driver side mount is broken lol. Just curious to anyone else that has had this issue. OEM replacement or eastcoast euro?
I think that that they must have been on the way out since I have been giving the car lots of hits well before the DP when it was just a tune. Any info is appreciated thanks.
Old Mar 25, 2020 | 01:35 PM
brutus_tx's Avatar
2014 AMG E63S and 2020 AMG GTC
I replaced mine with OEM at around 50K as well - all three
I'm 35K in on my second set, with about 50 launches under its belt.
The drivers side mount takes the worst beating.
Old Mar 30, 2020 | 11:35 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
You change the trans mount yet? Track launches beat mine up.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Mar 30, 2020 | 11:48 AM
brutus_tx's Avatar
Yes all three, both engine mounts and trans mount.. all OEM replacement parts
Old Mar 31, 2020 | 01:56 PM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
Totally normal. My mounts were replaced by warranty at only 38K. Fortunately my ELW goes through 1/22 so I will likely be having them done again under warranty. That ELW was the best investment I may have ever made!
Old Apr 1, 2020 | 04:23 PM
13pp63's Avatar
E63s
Elw is covering it thanks guys
Old Apr 6, 2020 | 04:06 AM
thabigo22's Avatar
2014 E63S
I meet with the owner of eastcoasteuro today since he is local and he makes some solid mounts.Should me how to assemble them and the quality of them vs OEM. He just came out with a newer version for our cars I am going to be one of the testers. I will do a separate post with my review of them once I get them on the car
Old Apr 6, 2020 | 06:49 AM
13pp63's Avatar
E63s
Nice keep us updated maybe after I destroy these ones I’ll go that route. Lol
Old Apr 6, 2020 | 08:53 AM
BCP's Avatar
BCP
2014 E63s
@thabigo22 means they are well built when he says "he makes some solid mounts". They are poly and billet, so not an actual solid mount. Just wanted to clarify.
Old Apr 6, 2020 | 11:50 AM
Sugar_Mouth's Avatar
2014 E63S, 2018 GLC 300
Did you go with the street density?
https://eastcoasteuro.com/services/
Old Apr 6, 2020 | 11:53 AM
thabigo22's Avatar
2014 E63S
Correct those are the ones I plan on installing on my car.
Old Apr 6, 2020 | 12:06 PM
BCP's Avatar
BCP
2014 E63s
Yes, i plan to go with the street density version -- they seems to be a reasonable choice for enhanced durability wile retaining some smoothness. They are serviceable, so you can always buy the higher durometer poly inserts to swap in should the need arise.
Old Apr 6, 2020 | 03:13 PM
Sebastian Bird's Avatar
2014 E63 AMG
Are you doing engine and trans mounts? I spoke to him too about testing then out but I've just had to lay out for new brakes and tyres.
Old Apr 6, 2020 | 03:25 PM
BCP's Avatar
BCP
2014 E63s
Just engine mounts; I suspect the OEM trans mount will be fine without excessive engine movement, and ECE does not offer a poly mount for the 722.9. How are the R888s working out for you?
Old Apr 6, 2020 | 03:37 PM
2014 E63 AMG
Just checked my messages they are doing a trans mount to test. Unless they've decided against it this was in January I spoke to them.
Not got them yet but I swapped some other rear wheels I bought with Michelin PS2's on them and they get so much more traction than the pirelli. I will never buy pirelli again.
How did the Dyno go?
Old Apr 6, 2020 | 09:44 PM
BCP's Avatar
BCP
2014 E63s
I'm not sure -- he said they were thinking about it when we asked last night.
Nice, cant wait to see some improved tires now with more traction! Definitely sounds like the Pirelli didn't work out so well.
The Dyno went well, good starting point. I sent Jerry the logs and he is tweaking it.
