Brembo rotors
Hey guys I’m new here but have been lurking for a long time and need some help. I bought new Brembo front rotors for my 2016 E63. My mechanic is telling me they are too thick and hitting the calipers. Has anyone ran into this before?
Nick |
Nick, welcome to the forum. Please post your vehicle info and Brembo part numbers you purchased. We can comment at that point.
@maxusa i have a 2016 e63s and purchased the Brembo 09.9764.23. I gave the vendor my vin and all info and they are telling me they should fit. Thanks for any help you can give
Nick |
Hello Nick, it looks like Brembo rotors 09.9764.23 show equivalent to Mercedes p/n A2194210212, which is applicable to early W212 (with M156 engine). Here is the applicability across the 212 models in the North American market:
Bond brake disc, front p/n A2194210212 212.077 E63 AMG 2WD Sedan MY2010-2011 Bond brake disc, front p/n A2124210512 212.074 E63 AMG 2WD Sedan MY2012-2013 212.274 E63 AMG 2WD Wagon MY2012-2013 212.092 E63 4MATIC Sedan MY2014-2016 212.076 E63 S-Model 4MATIC Sedan MY2014-2016 212.276 E63 S-Model 4MATIC Wagon MY2014-2016 with B06 (Silver) and U70 (Red) calipers without B07 (Carbon Ceramic) system I installed the same Brembo rotors in my W211 E63 several years ago. They are great, and prices can be very competitive. Hope this helps. |
Those Brembo "09.9764.23" 2-piece Rotors also fit perfectly to "W212 E63",,
why mechanic said; they're too thick..!?!?! -;-ZAYED-;- |
I looked up WIS article "Inspect condition of brake disks" AP42.10-P-4258EW as of 22-MAY-2017. It has relevant spec BE42.10-P-1001-08P updated 04-MAR-2016:
212.074/075/076/077/092/274/275/276/277/292 except code B07 (carbon ceramic) Brake disk thickness: new 36 mm, wear limit 33 mm This thickness spec and designation is the same across all 212 E63 models in North America. This thickness spec is also the same claimed by Brembo 09.9764.23, other dimensions notwithstanding. You may want to verify that you (a) received the correct Brembo parts, (b) that rotor thickness is 36 mm, (c) that some other dimension is "too thick" and contacts the caliper (like the hubcentric portion). The tech can compare the original part on the car to the new parts or the diagram. Remember that Mercedes part numbers are indeed different as mentioned in my previous post. Hope this helps. https://cimg6.ibsrv.net/gimg/www.mbw...bcefe5bc73.jpg |
^^--Great write up--^^,,
Yeah, almost all 07-16 "63's" sharing the same Rotors spec.,, whatever 1-piece or 1.5 or 2-piece..:) -;-ZAYED-;- |
I found this W204 discussion about the AMG brake rotors from several years ago. Pics included. Might help.
https://mbworld.org/forums/c63-amg-w...ml#post6304989 |
I see the same at FCP Euro.
When I look up brake rotors for my 2013 E63 (212 074), this exact Brembo part shows up as a replacement. Also when I change the model year to 2016, same results show up as this being an OEM replacement. I don’t think you should have any problems fitting. |
Originally Posted by ncardw
(Post 8082904)
Nick Go with the information in this thread, https://mbworld.org/forums/w212-amg/...rs-dealer.html i have these exact brembo fronts and Zimmerman rears from FCP euro which are lifetime warranty and you can replace them anytime for free. I go through rotors about every 15,000 miles and will never pay for another rotor again when you buy them from FCP euro. My Indy charges about 300 per axle to replace the pads and rotors, so for under two grand with a good indie you get everything replaced with a lifetime warranty on the parts. https://mbworld.org/forums/w212-amg/...rs-dealer.html |
I have the same rotors and have zero issues. This is really strange.
So, I decided to try and replace the front brakes myself since you guys convinced me that these Brembos would work, and they fit perfectly. I’m not sure what was going on with my mechanic. Maybe he just didn’t want to work on a Mercedes on a Friday? Anyway thank you for all the info
Nick |
(Post 8086657)
Nick Where did you get the rotors from? I need some for mine soon |
Originally Posted by SAMzE63s
(Post 8087037)
I think its time for a new mechanic lol
Where did you get the rotors from? I need some for mine soon Yes that is correct, you pay for the rotor 1 time and when you need to replace it you buy another from FCP and then send back the old one you bought. I thought it had some gotchas but it’s exactly as they advertise and you’ll never buy a 2nd set of rotors or pads again. https://mbworld.org/forums/w212-amg/...rs-dealer.html |
(Post 8087037)
