Trigger to shut down boosts (when meth runs out)
Old Sep 16, 2020 | 12:42 PM
cls5504matic's Avatar
C63 Vert
Anyone know of anyways to shut down part of the boost table. Some cars you can make it so the ecu thinks there is a cooling issue, or other and it will prevent high boost levels.
The idea is that upon methanol running out, boost levels are curtailed automatically. Right now I am thinking we can tell the ECU that the IC pump or some cooling may not work. Or potentially code something in the ECU where upon signal it drops the boost levels.
With this mod we should be able to run very aggressive methanol cooled boosts safely.
