Tilt Steering Wheel Problem
Thanks.
I moved the steering wheel all the way towards the driver's seat, then pushed down on the lever and hit the top of the steering wheel a few times .. after doing this, I wondered if it would be possible to somehow set off the airbag
. So I switched to pulling down on the steering wheel while pushing the lever down, and after a few tries it freed itself. Thanks!
That's what I did and it worked. Make sure you turn off easy exit feature so it doesnt happen again.
My electric lumbar adjustment on my Sequoia got stuck in the highest position so I tore the seat apart. Found that it’s a simple mechanical actuator with a metal rod and at the max setting it got stuck due to lack of lubrication. Giving it a good pull resulted in the bar breaking free and it now works fine.
Similarly my guess is there is some design element on the Merc tilt that gets stuck and the motor cannot overcome it. Had the same issue on my E550 and was also solved by physical force.
