White Smoke Drivers Side 2013 E63
karpetcm (01-22-2021)
do a compression test... Could be a blown turbo aswell.
karpetcm (01-23-2021)
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Received 3,930 Likes
2017 GLE350 4MATIC
What does the smoke smell like? Steam/sweet, or burned oil? Or gasoline?
Does it smoke at constant idle? Does it smoke more or less when the rpms are blipped? Does it smoke more or less at WOT?
2017 GLE350 4MATIC
Unburned fuel. What service or repair work has been done in the past 6 months?
How does it idle? What is the fuel economy. Probably a hard question to answer with a V8 AMG.
car idle smooth and pulls strong i had no clue it smoked till a friend following me told me. Just did a oil change 2 days prior. Plugs are 8 months old maybe 1200 miles if that. Has changed coils. No miss fires.
2017 GLE350 4MATIC
OK. If it smells like gasoline, it's gasoline. What do you think is causing the white smoke on the driver's side?
If it is gasoline, continuing to drive it with an over fueling injector will damage the cylinder. You could test to see if it is that by unplugging the first cylinder injector and starting the car. It will run rough, but, if that’s the overfueling injector, the white smoke will stop. If it doesn’t, plug it back in and move to the second cylinder... etc.
if it doesn’t stop, it’s something else, such as a turbo leaking oil at the shaft seal.
There are known instances of injectors sticking in these cars so, it’s possible. I’m inclined to think it’s coolant or oil, however, as white smoke is typically coolant or oil.
have you checked the fluid level in the intercooler reservoir to see if it’s full? Maybe a pinhole in the heat exchanger on the driver’s side?
Its at the mechanic shop now getting checked. I had a reservoir tank leak before. The one on the passenger side a couple if days before and was fixed problem with the smoke is there before or after that fix. Hopefully he finds whats wrong, he doesn't think its anything major but that to me means nothing. I take pretty good care of my cars and this is major to me. Could be a leaking injector, could be a head gasket, not sure just yet.
Received 2,036 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
karpetcm (01-27-2021)
